Fernando93
- Jun 27, 2017
Yes, you can install the FTW3/Kingpin without problems, just cut yourself some low profile Molex 8 Pin PCIE Connectors if you have a Kingpin.F**k! I've forgotten to plug in my RAM yesterday! Yes - it seems to be a big problem! F**k, F**k - I've higher LED RAMs!
Second: are you able to install your EVGA GPU with this alignment of the AIO? The second tube is sitting just in line with the long gpu!
Did you removed the front USB? Do you see a chance to reinstall this?
For the front USB problem just trim the plastic as Nhede did
Nhede´s pictures:
