if you can't beat them join them , been mining on my 1080 overnight before the dan case got here and I'm almost half way to making the case back.Maaan, why is the EVGA 1080ti FTW3 (black) sold out everywhere, f*cking miners
I have the LP53 + Noctua A9x14, and find the setup actually noisy. It must be how I attached the fan, or how it touches the RAM stick?
Here's a picture of my build, is that how we're supposed to attach the fan?
Corsair SP 600 + Asetek 92mm AIO /w Noctua NF-A9-14
.... realized a problem - the PSU cables were pushing down on the noctua fan just enough to prevent it from spinning, so temps flew out of control. Currently, the PSU is outside the case while I try to figure it out. Anyone have a similar problem?
Yes, I do.
The cables at the bottom of the Corsair PSU is causing a problem, there are too many, too long cables.
I made it 'work' by flipping the PSU 180° and removing the small bracket where you normally mount the PSU on. That way the PSU is not mounted at all, but it is so tightly packed with all the cables that it does not move anyway. The cables now have to be connected at the 'top' of the PUS instead of bottom. The one main power cable to the PSU can be connected at the bottom of the PSU.
Problem with that solution is that the PSU sucks air and blows it out at the bottom directly where the AIO cooler sits, but temps are ok so far.
I don't think this can be a permanent solution (maybe by drilling some holes into the PSU shell to enable fixing while flipped on the removed bracket and changing the PSU fan, so that its air flow is reversed (fan of PSU has to be flipped).
TO still be able to use the initial 'correct' PSU mount setup am looing into modding the main power cable going to the mainboard and the PCIe power cables to something like this:
http://www.abload.de/image.php?img=p10109842t5h.jpg
source https://www.hardwareluxx.de/communi...-einen-abgewinkelten-pcie-stecker-683614.html
Are they the Corsair SF custom pro cables? Can you please post a pic once they're in your system?I‘ve ordered these cables for the psu..
Think, these will be easier to handle
How much were they? (It seems they're not sold in France or I couldn't find them…)I‘m waiting still for these cables. Amazon has been skipped my first order from last week... grrmll
Those are the cables in my A4-SFX build pics. Cheaper then the alternative, but they're the same lengths as the SF PSU standard cables, i.e still way too big. How that affects you depends on how you're using the case. In the case of me having to stash 98% of the length of a 445mm long SATA power cable above my full size bottom fan among other excess cables, not well.Corsair CP-8920202 Premium Sleeved SF Netzteil Kabel-Set schwarz https://www.amazon.de/dp/B01MRWN5M2/ref=cm_sw_r_cp_api_g21BAb81EV1VS
Here are two pictures of an epic x299 build of an German based A4-SFX customer:
Full-Sys Specs:
AsRock X299E-ITX
Intel i9-7920X, 12 Core,
Asetek 545LC + Noctua NF-A9x14
4x Ballistix Sport LT 16GB DDR4 2666 (64GB)
Samsung 960 Pro 2TB
Corsair SF600
EVGA GTX 1080Ti FTW3 12 Gbps Elite
I saw this clean way to use cables... I‘ll try to do it so
Has anyone here tried the ITX30 cooler versus the LP53? Seems like both do the job of cooling up to a 100W TDP, but the ITX30 would fit in an A4 without removing/replacing the fan. Does it work as advertised and is fairly quiet?
Do you mean the cables that originally come with the Corsair PSU? They come glued together in a sort of ribbon so will you just split them up individually? Looking at them you could easily add your own colour sheath to personalise it a bit! How much was the crimping tool?Thicker sleeved cables are more difficult for this case to swallow. You're probably better off with the default cables shortened. They're after all very thin dividable individual cables.
In the meantime, I ordered a crimping tool, the pins, and connectors to shorten the cable and they were about 30 dollars in total
That's a great solution for extra fans, I would reverse the direction of the bottom one and the aio fan though personallyHave now ordered 2 akasa 80mm slim fans for mounting below and above the Mainboard. The cpu will be cooled with an Asetek AIO.
May question is now: how about the air flow?
the AIO blows hot air to the bottom of the case (may be higher Standing feets would be a good suggestion to raise the case a Little bit?). The lower case fan below the Mainboard should blow also down - not to get the hot air from aio back into the case, right?
the fan above the Mainboard could also blow outsde the case.... but is the airflow ideal with this config?
May be the fan above the Mainboard should better bring air from above into the case?
If I note the gpu, it is probably better if both case-fans blows out the case. Then it helps the GPU for their airflow too. But then I do not know if the board has much of the two case fans.
Overall, it is semi-optimal that the AIO and the warm air of the GPU sucked in part with ...
(Load Temp) Reviewer says "ITX30 does MAX speed spinning but LP53 comparatively quiet in Linx"
Thermolab ITX30 QHQG: 1485 RPM (79 W)
Thermolab ITX30 Core i5-6600: 1997 RPM (122 W)
Thermolab ITX30 Core i7-6700: 2472 RPM (142 W)
Thermolab LP53 QHQG: 1281 RPM (79 W)
Thermolab LP53 Core i5-6600: 1608 RPM (122 W)
Thermolab LP53 Core i7-6700: 1762 RPM (142 W)
this is result by thermolab's bundle fan
as you see, lp53 fan is bigger and heat sink also bigger.
so... i think, you better do cable tie !
Reviewer(http://hwtips.tistory.com/1910)
D10S
the right way of the AOI radiatorfandirection should be allways directly outside the case, right? mounted at the bottom of the case, the hot air (and it is very hot there) would be pressed down outside the case. (But there is a chance to get some of the heat back in case by building a loop of a percentage of the air...).
If the direction should be upwards, you would heat your psu and GPU with the warm air from cpu/AIO. In this case, I had care about the cables of the psu. The heatspot there would be enormously strong!
in case of gffermari - it's a pure aircooled solution. there a airflow from bottom to top should be allways ideal.
the best postition of the aio Radiator would be above the PSU.
Hi Don,Why not getting a FSP 500w flex psu and mount it on the position your radiator is. Then you can mount a 120mm radiator instead of a sfx psu.
And speaking of the fan, it is a little loud - think it must be due to turbulence. Anyway, I run it on 45% until temps ramp up - this keeps the build completely silent until it has to perform
