lappenlappen
- Aug 31, 2017
dondan same question from me preordered and payed for v1 but on caseking.de that became v2 with a looooooooong wait a year or so hoping to have the case in hand jan/ feb =)
you should check casekind and overclockers website regularly. In the last month or two I saw both the silver and then the black V1 A4 units in stock, but they get sold out in a few days.
Going aio so will wait for v2
custom watercooling with 92mm radiatorDoes Dan have a AIO temp test with that Astek system? Seems like horribly poor intake/exhaust.
Can you list the components used for that loop please? Also are you still able to use the front usb?custom watercooling with 92mm radiator
Got a reply from caseking that preorders will be shipped in january though if its new or only old preordes wasnt in the reply, hopefully/guessing that dondan has stock/planned for thatahh okay, I am waiting for the V2 also.. interested to see when well be able to receive the V2 pre-orders. Hopefully not another year D:
It's too thick.Would the Alphacool NexXxoS XT45 Full Copper 92mm Single radiator work with the Dan Case using an AIO Pump and a NF-A9x14 PWM Fan?
Upgraded my Asus ROG STRIX-GTX1080-A8G-GAMING to a Asus GTX1080Ti Turbo - the Strix version of the GTX1080Ti is 2,5 slots, and doesn't fit the A4-SFX...
The turbo seems so small compared to the Strix!
View attachment 43182 View attachment 43183 View attachment 43184 View attachment 43185
I had the very same issue on my Asus Z370I and could not find a solution on the web when I searched for it ~2 weeks ago, a couple of days later I'm reading this post here (!), tried it out, and no problems since then. Amazing - thanks a lot Ceski!!!That's the infamous cold boot issue which Asus refuses to acknowledge to this day. Basically, the theory is Asus really messed up the Auto settings for the Z270I when you run any typical memory kit that's not DDR4-2133. Which is nearly everyone. The solution is methodically changing the VCCIO and System Agent voltages until the system reliably cold boots (boots after being fully unplugged for a minute or so). Some typical values are listed here. This solved it for me.
Edit: to add, if you power cycle three times, it will load bios defaults allowing you to make changes.
Thinking about doing the same. Note any performance improvements and temperature differences?
How did the noise change?
Well, performance went wayyy up, but the noice also went a little up.
Comparing the GTX 1080 Strix to the GTX 1080Ti Turbo comes down to this:
- The Turbo's Fan always spins at idle at 20% or some 1300RPM and is hearable then, whereas the Strix's fans did not spin in idle and made no sound.
- That also makes that the Turbo is some 28°C idle and the Strix was 45°C
- Playing a lengthy game (Wolf2, Doom, Quake Champions) ramps up the Turbo's fan to 55% (2700RPM) while keeping it under 85°C, and this is very hearable - the specific high pitched sound of a turbine fan. The Strix never got warmer than 75°C (don't remember the RPM)
- The exhaust air at the read of the Turbo is a lot warmer than with the Strix, but this also makes that the rest of the interior of the Dan A4-SFX is a couple of degrees cooler.
I must say that these findings were with both sidepanels installed for the Turbo, and both sidepanels removed for the Strix. I'll see what it gives when I remove the sidepanels and play games with the Turbo.
View attachment 43395 View attachment 43396
(yes, Hardwaremonitor still displays "GTX 1080" but it's really the GTX 1080Ti
After having tight funds for a while I am finally getting around to my Dan A4 (v1) build and had three questions.
First, anyone have used a 960 EVO from an SSD that is limited by the SATA bus"(MX300 for example)? I currently have a Sandisk Extreme Pro and am curious if the M.2 drive is worth it.
Second question is if anyone sees a problem with my build?
My Parts list is:
Ryzen 1700X
ASRock B350M
Noctua NH-L9a
G.Skill Ripjaws V 2x16GB
Sandisk Extreme Pro 480GB
Samsung 830 pro 256gb
EVGA 1070 SC ACX
Corsair SF450
Lastly, anyone have and favorite tips or tricks from their builds?
32gb will be hard to get high frequency to work. All looks good but spend some time researching the ram unless you already have it.
Please note what you have added to the list is a micro ATX motherboard and the case only fits mini ITX motherboards. For Ryzen there are currently 3(4) motherboards available:ASRock B350M
If you're asking whether there's a noticeable real-world difference between a SATA M.2 SSD and an NVMe M.2 SSD, then I'd have to say that in my experience I can't tell the difference between the two in general operation. I guess if you have a particular use-case where you have sustained, prolonged writes or reads then you may find there to be a difference, but I can't tell the difference in Windows or with game loading times, for example.First, anyone have used a 960 EVO from an SSD that is limited by the SATA bus"(MX300 for example)? I currently have a Sandisk Extreme Pro and am curious if the M.2 drive is worth it.
Well don't you get a 50-100mhz (depending on if you have an X or non X chip) boost increase on and x370?Please note what you have added to the list is a micro ATX motherboard and the case only fits mini ITX motherboards. For Ryzen there are currently 3(4) motherboards available:
Asrock Fatal1ty AB350 Gaming-ITX/ac
Asrock Fatal1ty X370 Gaming-ITX/ac
ASUS ROG Strix B350-I Gaming
ASUS ROG Strix X370-I Gaming
Biostar Racing B350GTN
Biostar Racing X370GTN
Gigabyte AB350N-Gaming WiFi
Please note that while I listed the X370GTN it offers no discernible benefit over it's B350 counterpart
No. Where is this information even coming from? That extra boost is XFR and that's from the chip...not the chipset.Well don't you get a 50-100mhz (depending on if you have an X or non X chip) boost increase on and x370?
On the other hand, if you're buying a new drive anyway and the price differential between SATA M.2 and NVMe isn't too great, you might as well go for it. But I wouldn't go out and buy an NVMe drive to replace a perfectly good SATA one.
Don't get me started (again) on those stupid heatsinks it annoys the hell out of me. These boards are so expensive and they can't even give you proper heatsinks.If the VRMs on the Asus z370 are like the z270, just remove them. You get much better airflow in the Dan case that way if your fins are oriented such that they block air. If you're worried about cooling buy some low profile heatsinks and stick them on. The obnoxiously huge VRMs are basically marketing gimmicks.
Is it easy to remove them?
2 screws.
Is that hard? Lol jk... Once I remove them would I be required to replace them with another heat sink or are they a low source of heat? Thanks
I would VRM can get very hot, especially if you overclock.
Alternative VRM heat sinks?
