What speakers are those?
Yes, I had the overheating issues too. There is basically no air flow, so I didn´t use it in the end.Are there, or have there been any overheating issues with M.2 NVME SSD's on the the back side of boards with this case??
Can you be more specific?i have problemas with 1080ti FE and asus z270i.
About that Bitspower adapter, how tall is it? My upcoming case has clearance of 44mm so with the Nocuta being 37mm I only have 7mm to play with.Bitspower fan adapteri used a dremel on it
It is possible...Seems u are just buying the wrong Hardware without research
In my silent Mode,my 1230v3 is in pubg @70 degrees with the nh-l9i and the Fan @1200rpm! Msi 1070 Quick Silver at 63-65 degrees and 1000-1100 RPM.
I wonder if the top mounted with heatsink M.2 boards like what Asus offers would be ok?
I have asus z270i and i have m.2 ssd 960pro in front slot. Temps never went above 80°C (in benchmark) with added heatsinks:
In idle I have about 40°C.
RASPBERRY Pi RB-Heatsink
But I have also 2 noctua fans above taking the heat out of the case, so it makes a difference too.
I have problems with temps in the back of the motherboar, more than 85°. In the front without heatsinks around 68-70°Yes, I had the overheating issues too. There is basically no air flow, so I didn´t use it in the end.
I have also managed to install 4x 40mm noctua fan in the case.
If you are interested, I can post a pictures.
80° trottling
Trying to decide between Asrock Fatal1ty and the Asus Z370I. Which would be best in this case? I do have a Samsung 960 EVO 1TB and plan on doing a slight overclock on the 8700K.
I'd be happy with 4.3Ghz(all core turbo) in the Dan case and cooling.Or maybe the TIM is better. I assume we won’t be able to run the 8700k with more than 1,15V without overheating. Therefore we are very limited when it comes to overclocking. Do you think 4,4 Ghz on all cores is a realistic value?
From my favorite hardware review side in Germany they said the 8700K is easier to cool. With the same heatsink 13°C less temperatures. But as you know every sample is different maybe the 8700K sample was a very cool one or the old 7700K a very hot one.
I have Also looked at the New coffe lake chips, and i see the i7 8700 is rated at 65 tdp, and the i7 8700k is rated at 95 tdp. Would the non k, be a better match cus it runs cooler, or does the 95 tdp for the k versions just mean that how Much heat it can generate if its max overclocked?
Hi guys, I'm new. I have a A4-SFX but I'm using is as a low power media server. Anyone tried the Noctua NH-L9x65 cooler without the fan? It's 51mm without the fan, 3mm too high. Does anyone have any experiences with lowering this cooler by 3mm? Preferably by bending the heatpipes and not cutting the fins.
Won't using lower standoffs mess up the alignment between the motherboard/case? I think I'll just take the easy route and go for the Phanteks PH-TC12LS (47mm wo fan) or Prolimatech Samuel 17 (45mm wo fan) ...or Thermalright AXP-100 @44mm
the non-k is a better match for this case. A4-SFX only supports small heatsinks. 8700k will work, but it will throttle more. you can save money and buy a 8700 if you want.
we must test this to make sure, but I believe a 8700 will perform the same as 8700k when using small heatsinks. the only way the 8700k can be faster than 8700 is if the fan runs faster and more noisy...
in the end, ANYTHING will WORK, because modern CPUs down-clock automatically for safety when overheating. I personally believe 8700 (or 8700k down-clocked like 8700) is more appropriate because it is more energy efficient.
I would still say always go the the K over the non-K. Where I live, they are the same price, og within 1-2%, and then undervolt it, so it will match in heat-output but be more powerfull.
Thanks. I think I'll just go with the the standard standoff. I'd like to keep the look as "pretty" as possible. TBH even the stock cooler without a fan will probably suffice. It's only for music playback, and running Linux without a GUI. Besides, when I upgrade the motherboard in the future I'll probably need to use the standard standoffs or there won't be any room for back mounted M.2 SSDs. (not a big deal in itself but then the cooler won't fit)It just messes up alignment with the IO plate, but a lot of us left that off for better temperatures anyway.
^ You should have turned your heatsink 90 degrees, fins in vertical orientation, so air can more easily flow upwards. It's also better for heatpipe performance. Which heatsink is that anyway?
http://www.evercool.com.tw/categories/global/cooler/cpucooler/intel/1366/hpl-815/hpl_815.php
The fan dont touch the riser?can not rotateCode:http://www.evercool.com.tw/categories/global/cooler/cpucooler/intel/1366/hpl-815/hpl_815.php
