JackGLemmon
- Dec 8, 2016
Anybody knows if and when will asus release an am4 mitx? I would prefer the Strix over the Gigabyte gaming. I'm thinking of a R7 1700 and GTX1070/2070 build for my Dan case. Can wait for Volta but I'm not sure about Ice lake since it might take forever before Intel to release it. I'm slowly buying parts now for that January build![]()
Asus will release AM4 Mitx, unless the past can not predict the future. Mitx is close to a laptop with huge expansion possibility, and we always see a lot of work on the motherboards compared to the almost cookie-cutter Micro-ATX boards.
You want all your parts to be bought so that the return periods overlap. Otherwise, when you are able to test your parts together you may find broken/incorrect items and be unable to return the bad parts.
Hi
I'm a new member, have been following hardopc and this thread since dan case v1 there are alot if interresting posts that kept me waiting and waiting and waiting, hopefully I will get my v2 with the 92mm Noctua NF - A9x14 in january according to the info.
To my question, I hate my case, I hate my computer, I just want to scream.
Right now I will trash my computer and keep some things until the dan case arrives, I was hoping for suggestions what to buy. (that can be transferred to dan case in january)
Most is old shit (intel ddr3 and so on it will be retired)
I will temporarily keep my Node 304 (which I hate, and it will burn in hell when the dan case arrives) or maybe switch temporarily if any cheap suggestions just for mental stability
I might keep my PSU SilverStone Strider Gold S ST85F-GS 850W but I think it's a bit to big so I might switch it (maybe it's a good fit for dan case, but not for the node and the cables are insanely long)
I will for now keep my GPU Sapphire RX Vega 64 (for freesync) hopefully it will not melt the dan case
Im going Ryzen 7 (1700, 1700x or 1800x) don't know the difference yet exept price
a mini itx ryzen mobo (seems there are some problems with them, trying to find a match)
DDR4 (seems ryzen wants more speed)
A NVME/M2 (pci-e) 500GB SSD samsung seems to be a good bet 960 evo or pro (with a passive heatsink)
For coolers i think it might be best to wait until v2 comes and go stock until then?
I will not overclock though I might underclock (never done either before, just reading in this thread) if there is major noise/temperature gains without to much performane drop. (therefor abit unsure about CPU)
Any suggestions regarding this so I can have a working PC until january dan case v2 (transfer of the components to that chassi)? Im to afraid to order and something will not work together or not fit later
This is really not the appropriate place to solicit upgrade advice, but I understand that you want your upgrade to be designed to fit into the Dancases A4-SFX. It is never good to buy part of a collection that is meant to work as a system separately: it limits your eventual flexibility.
If you have a quad-thread processor from Sandy Bridge (2011+) and 8+ GB of system memory, then you should stay put on your core platform. It sounds like the combination of the Node 304 and the PSU are driving you crazy. I think you should buy a new power supply unit, as the A4-SFX will require an SFX power supply and you have an ATX power supply.
I would suggest you buy the Corsair SF600, as it will leave you with more space for cable management then alternatives. Be sure that you buy SFX power supplies and stay away from SFX-L power supplies. If you had trouble with cable management in the Node 304, you will need every advantage you can get in the A4-SFX.
https://www.hardocp.com/article/2016/06/22/corsair_sf600_600w_sfx_power_supply_review/
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=477
You can use an SFX power supply in the Node 304 by using an ATX-to-SFX adapter plate. Both SIlverstone and Corsair make adapter plates.
https://smile.amazon.com/dp/B01BYB33J8
http://www.corsair.com/en-us/sfx-to-atx-psu-adapter-bracket
I expect that you could also be complaining because the never-quality and now-old case fans are loud. You should replace them all with their Noctua equivalents. You will need a PWM fan-plug splitter. I included fan grills because they keep cables out of fans, but you might not want them because they cause airflow noise and cost money. One 92 mm fan could be moved into the A4-SFX.
Finally, a PCPartPicker list with the items you need to ease your short-term case pains!
https://pcpartpicker.com/list/M3wJLD
