Julio Espinosa
- Feb 1, 2017
I did delid my 7700k my temps hover around 40C idle iircHows your temps? Did you delid?
Sorry guys I must leave this here very quick.
Today I got the Lian Li samples and currently my system is running Prime95 with a crazy room temp of 25°C.
The copper edition with the thermalright 100mm fan perform nearly on the same level as the Asetek AIO with a room temp of 21°C. So the HSLP-48 is 3°C better as the AIO and 13°C better as the Dynatron T318.
Now It will try 4Ghz XD
[...]So the HSLP-48 is 3°C better as the AIO and 13°C better as the Dynatron T318[...]
Can you install the slim 120mm fan from Noctua or is the max 100mm?
YEAH!!!! That fan is insane!!!!!!!dondan Regarding the noctua fan, this may be of interest to you: http://www.pcgamer.com/noctua-spent-four-and-a-half-years-designing-its-quietest-strongest-fan-yet/
Because nobody with this case is interested in information regarding the cooler that is being developed specifically for this case.Wrong thread.
I posted in the wrong thread I meant, I suppose I was unclearBecause nobody with this case is interested in information regarding the cooler that is being developed specifically for this case.
Let's have a raffle!Woe!!! dondan do you have to give those heatsinks back once you are done with the testing? Can I buy one of them off of you?
Probably, or because he is not done yetWhy no results for nf12x15 under, does this interfere with mb components?
Yup, with the x99e-itx and his current ram config he is unable to use the noctua slim 120mm cooler.It'll interfere with RAM
And with the 8pin CPU power (EPS) connector.
I tried a set of Crucial VLP DDR4 (CT16G4XFD824A 2x16GB). It runs fine with both 7700K/Z270I and 1700/X370GTN. stressapptest stable at DDR4-2666 14-14-14-34-1T 1.35V with tight secondary/tertiary timings. Not great, but it's ECC Micron memory and I'm surprised it even works. Probably a decent match for dondan's cooler with a slim 120mm fan. In the ideal world we'd have some B-Die VLP sticks.Nice ! Keep us updated please , one more question , which motherboard you will going to use ? Some boards needs a mosfets heatsink replacment if you going to use the 120mm fan
Yeah, no problem. In the spoiler:ceski
Thanks for the update, can you please share the vlp ram part number (Micron part number not Crucial) (on the right sticker start with MTA.
Because I was thinking of this one:
MEM-DR416L-CV02-EU24
From here
And I was wondering if it is the same
Here is a small preview of my tests today with the HSLP-48. (Copper vs. Alu)
The benefits of copper vs. alu will be smaller on lower RPMs.
i7 5820K default clock (3,4Ghz) and volatage, Room temp 25
HSLP-48 Copper...|...TY-100...|...Pull...|...2400RPM...|...63,8°C
HSLP-48 Alu.........|...TY-100...|...Pull...|...2400RPM...|...67,2°C
HSLP-48 Copper...|...TY-100...|...Pull...|...2000RPM...|...66,5°C
HSLP-48 Alu.........|...TY-100...|...Pull...|...2000RPM...|...69,3°C
HSLP-48 Copper...|...TY-100...|...Pull...|...1600RPM...|...70,2°C
HSLP-48 Alu.........|...TY-100...|...Pull...|...1600RPM...|...72,8°C
HSLP-48 Copper...|...TY-100...|...Pull...|...1400RPM...|...75°C
HSLP-48 Alu.........|...TY-100...|...Pull...|...1400RPM...|...77°C
HSLP-48 Copper...|...TY-100...|...Pull...|...1200RPM...|...80,5°C
HSLP-48 Alu.........|...TY-100...|...Pull...|...1200RPM...|...82,3°C
In the middle of all values the difference is 2,52°C (max 3,4°C, low 1,8°C)
I'll still pay for the copper, 3-degrees is worth it, especially for those of us who go so far as to delid our processors.
