I took like 12-14H to make 24 pin white sleeved.How hard is custom cables to do yourself? i read up a bit on it and the stigma comes from potentially botching the whole thing up if your connections arent right.
I want to try for an angular cable style with hard 90 degree angles.
Might be too late for this suggestion, but it would be cool if at the end somebody slipped it into a Wallye Duffle and walked away.
With Premium shipment to US is 5 working days vs 15 working days.
Dondan, upon shipment, is it possible to under declare the package to around 100euro or less?
Under declaring wont work well, it's going to cause whichever countries customs department to stop the package in it's track to confirm the value.The Wallye Duffle is much larger then the Dan A4-SFX. The Tenba BYOB 13 is the right size, and is about half the volume of the Wallye.
https://www.amazon.com/Tenba-636-224-BYOB-13-Camera/dp/B00KT7G9UY
The Lowepro Event Messanger 250 is also the right size if you cut out the tablet pocket. This bag has doubled in price since many of us bought it last year, and is out of stock on Lowepro.com
https://smile.amazon.com/gp/offer-listing/B0077B403S/
Is that drop-shipping from Taiwan or is that coming from Germany so it can be blessed, re-boxed, VAT'ed, and taxed?
I doubt that would be economical, as that would require 3 shipments (side panels, frame, PCIe riser).
If you are student you can get any autodesk CAD software. Otherwise I would say get a free trial from autodesk or use sketchup.Whats the best free CAD software out right now? And what's the most reasonably priced for quality? I want to design my own addon to the DanCase.
Hey dan, will there be an option for us on kickstarter if we do the plan to not use the front USB to instead use an aio cooler to have the front panel completely flat instead of having an empty hole?
So just to check - if the user goes for the Asetek AIO cooler, we lose the front USB functionality and have to cut part of the plastic inside the case?
Is there really no way to save the front USB port?
The USB slot can still be used if you heavily modify the cable.
However, the AIO works well with Dan's X99 board because of the ram slot locations....
Mexico City.Where in Mexico hermano? My dad and grandfather go back and forth at least 6 times a year.
Dondan installed the Asetek AIO with the ASRock X99 ITX board, which has the RAM along the edge of the board closest to the bottom. This allows for a gap between the RAM and the PSU to run the hoses. The point made by maven1975 is that there may not be enough space for the hoses if the RAM is in the more typical place along the front edge of the board.What do you mean by dan x99 board??
I'm devastated. On tuesday I had finally gotten hold of all my parts (waiting the longest for the Biostar X370GTN) and the Cryorig C7 AM4 bracket. I put all the components in the case and was so happy. But... I only ran the system quickly as a test without the side panels on. Yesterday when I put them on I realized the Sapphire Radeon RX 580 Nitro+ is a few millimeters too thick. When I started the PC I heard the fans scratching against the side panel. I have contacted the retailer so that I can send the card back and get a refund. The problem is there suddenly is a shortage of RX 580s and 570s here in Sweden (But not last week!). Might just go and grab a RX 480 (even though it's a cooler that hasn't really gotten the best reviews, I just want a working rig!)
I have the RX570 Nitro+ 8GB and its working fine. I was under the impression that it is the same cooler as with the 580. Maybe you can check your installation? I had some trouble to screw the GPU to the case at the back but after some time I managed to get it right.
dondan
I know you're busy, but it would be great to get a simple yes or no on the Power button situation.
Is it completely the same from V1? asking because of the review by LinusTechTips saying it's kind of wobbly without tactile feedback.
Thanks!
(backer#600ish)
1. Rubber feets instead of metal feets for better grip with the same look
2. 92mm case fan mount point if you not use the hdd bay ( will also support Asetek 92mm AIO)
3. A cover plate for the GPU mounting hole
4. Better centered USB front port
5. Stamp-in motherboard stand-off instead of screwed ones
dondan
Mounting a 15 mm hdd at the bottom section does not fit the screw hole. Is it possible to modify version 2?
Just use the hdd bay![]()
I don't get it. Do you mean screwing on the top of the bracket? The holes on the side of the bracket is too high for a 15mm drive. There's no way to screw it to the bottom of the case too.
So many requests for tweaks lately, guys, the time for tweaks was 2 months ago when suggestions were being heard.
Maybe he doesnt like you? LOL jk. I found some luck when i tried pushing discussion on adding fan support below the psu stating there was room for a 92mm fan, and he said it was something he was thinking of too.![]()
dondan just likes to ignore me.
TinySeth No changes to the power button. I think the most customers are fine with it.
cowsgomoo2 The drive bay was designed to fit 15mm drives also in the buttom location. Do you have a picture for me so I can see why it not fit? Plz give me also the name of the hdd you use.
You have to mount it upside down, the rubber feet add another ~1mm to the height and it just fits, however, the drive does touch the bottom of the case as I mentioned in my extremely long post
He wont listen, i did ask for this before... /facepalm/Hi Dondan,
Thanks for your work on the Dan A4 Case. I love this little case with great power.
For the V2 is it possible to lower the riser bracket of the graphics card ? with juste 0,5mm MSI Gaming Card will fit perfectly, 1 cm will be greater.
Thanks
