Sure.
Cool idea, more pics please! If possible with the entire case panels mounted as well...
Sure.
Printed a fan bracket and stuck a foam gasket on top.
Prime95:
No Fan Duct: 93 °C
Fan Duct: 89 °C
PCH, M.2, and memory temps dropped by 3-4 °C. Ambient: 22 °C.
i7-7700K Delidded, 5.0 GHz, 1.312 V, LP53 + NF-A9x14 + no I/O shield.
More testing to do, thought I'd share.
Are you going to run at 5.0GHz as a daily driver?
Very clean build I am impressed.
The heatsinks from adafruit look way better than my copper heatsinks. xD
Looks great! Where did you get the foam gasket?
I've managed to install the heatsink/fan assembly from a EVGA GTX 1080 FTW (bought from eBay) onto my Titan Xp. Highest temps I've seen so far is 61C with an ambient of around 22C. Idle temps are extremely low at around 23 to 26C. Fan is silent at idle and about as loud as a PS4 Pro at full tilt. Boost clocks settle right at 2000mhz; I haven't touched the memory yet. Second image is my Titan X (Pascal)... I used it as the test bed in-case I did something wrong. Moved the Titan X (Pascal) to my second PC with a hybrid mod installed; third pic.
when is expected to start the kickstarter founding for the second version?
I reapplied the Liquid Thermal Ultra & the Thermal Grizzly but temps are still out of control. 3:40 into Aida 64 it his the thermal limits. This is with the sides of the case off. The Noctua fan is only spinning at 2000rpm max?. I also have it set with the sicker facing the LP53.
I have no idea how some of you are temping in the 60-70. Thermal paste applications are not THAT hard to perform. Im confident its making solid and even contact.
Looks like an Asus Strix z270i, with the VRM heatsinks removed and replaced by aluminium fins.
(Speaking of, ceski, how much of a difference did that make to temps and airflow?)
As promised:I'm going to grab a FLIR thermal camera and see what the board looks like next.
The DAN Cases A4-SFX is an ingenious design that takes a mini-ITX gaming system down to its smallest possible dimensions, and does so with style and premium build quality. It really has no flaws as it is, from design to engineering, perfectly executed. Any limitations are known going in, such as CPU cooler height and power supply form-factor, and these do not detract from the experience in my opinion as they are absolutely necessary for this enclosure size to work.
Yes, I cut down the base plate probably more than I needed too but I did not want to cause a short by contacting any components (cuts could have been cleaner but I did not have my jigsaw at the moment so I used my dremel):Did you have to do any modding to the FTW cooler to get it to fit on your Titan? I'm wondering if I could get this cooler to work on a 1080 Ti FE.
Prime95:
No Fan Duct: 93 °C
Fan Duct: 89 °C
I would take the .STL file that I posted to your favorite proto shop and get it printed in a color other than barf creme. Shapeways is okay (free shipping on first order).Can you make another one of these for me? I will give you the monees. Also what fan gasket did you use?
Yeah - as I mentioned, 65 was the absolute max with the case side off and a Cryorig C7 (default fan) in Aida64 after about 20 minutes in. I ran an encode under Handbrake for a bit and peaked around 80 or so. I'm curious how I would fare with the L9i (I'd rather not swap fans, etc. even though I know that's optimal). I have one so I may try it unless I feel too lazy to take the motherboard out again.I reapplied the Liquid Thermal Ultra & the Thermal Grizzly but temps are still out of control. 3:40 into Aida 64 it his the thermal limits. This is with the sides of the case off. The Noctua fan is only spinning at 2000rpm max?. I also have it set with the sicker facing the LP53.
thanks for the answer, can you even say when do you expect the first shippings to start?It will start end of May
Try swap your fan on the c7 for a Noctua a9x14 or ty100.Is there a consensus on the best air cooling solution for this case? I have a C7 and the fan is really loud.
Check out my post here: https://hardforum.com/threads/dan-a4-sfx-the-smallest-gaming-case-in-the-world.1799326/page-264
Shortened down version:
Please note that these temps can't represent "Real World Performance", I mostly just wanted to get an overview of the temperatures quickly - all these benchmarks are taken in the following way:
- 5 min
- Open Test Bench
- Idle temp in bios
- Bios reset, Ram upped to 2400mhz
Summary
- If you ask me today if LP53 is worth it? I really do not know. My results indicate that the C7 + Noctua fan might be a better option (more cost effective)
- I would recommend you try a C7 + a NF A9x14 fan on it
- The NF A9x14 is way quieter than the the C7 stock fan
Sound Levels
Some notes about the noise during the bios temp benchmarks:
- LP53 + NF A9x14 (quietest)
- C7 (slightly higher)
- Stock Intel (loudest)
Want to save money?
- Get C7 + NF A9x14
Got money to spare and want a kick ass full copper CPU cooler?
- Get LP53 + NF A9 x14
Got money to spare and want a kick ass full copper CPU cooler and with 4mm standoffs?
- Get LP53 + NF A9 PWM (over 35% greater air flow over the thinner Noctua)
It is exactly what I am using.
https://hardforum.com/threads/dan-a4-sfx-post-your-build-here-thread.1924512/For the life of me, I can't find the thread with all the pictures of people's builds for A4, can someone link me?
Please let us know how A4-SFX fits in the Lowepro Event Messenger 250 after the tablet pouch is removed. It may give the needed few millimeters so that I do not have to push or shake to get the computer to fit each time.
I do not want to cut out my tablet pouch as I had hoped to use it for a 11" 1080p 60Hz GeChic portable monitor if there was space. I still want to use the Event Messenger 250 for accessories and cables, even if I decide on something like the Tenba byob 13 for the case.
Prime95:
No Fan Duct: 93 °C
Fan Duct: 89 °C
I don't notice additional noise due to reflections, maybe because it's not flared out like yours or maybe because the foam absorbs some of the high frequency components of the sound. However, the seal the duct creates forces the air to be pulled in through the ventilation holes rather than the partial recirculation from within the case that occurs without the duct. This means that at high fan speed (>2000 RPM), there is definitely a slight suction sound that is not present without the duct. At reasonable fan speed, there is no difference in sound.For those who are using the shrouds, are you noticing an increase in sound reflection and thus louder fan noise for a given RPM? I noticed with my shroud the noise levels that temps are lower but despite the lower fan RPM, noise reflection meant that it was still louder. Maybe the use of foam in the recent shrouds mean this is less of an issue.
View attachment 22830 View attachment 22831
Credit to ceski for the initial idea! I don't have a 3D printer so I used some acrylic from a hardware store, my drill and jigsaw, double-sided sticky tape, and a Phobya 140mm foam gasket from Newegg to make myself a shroud. Dropped idle temps by 3-5C and load temps from 5-10C. That's on a de-lidded, undervolted 3770k at 4.0GHz under an LP53+Noctua a9x14.
