dPunish3r
- Nov 7, 2013
And now the bad news, the Z270 Strix will not fit because of the phase heatsink.
Compatibility with Strix Z270i is mandatory.
PS. I would pay up to $120 for this kind of heatsink.
Nooooooooooooooooo!And now the bad news, the Z270 Strix will not fit because of the phase heatsink.
Thermal right is the easiest to adjust. The AXP-100h is 51mm tall without the fan. Only adjustments needed to make the axp-100h in to our perfect cooler is to reduce it by 1mm, extend the fins and add a fan mount underneath the heatsink. This is by far the easiest to implement vs going to any other manufacturer.
Noctua is great but they would have to do far more work than what Thermalright would have to do. A 120mm fan, regardless of how slim it is, will be far less compatible than the 100mm specially in a mitx that is already cramped enough.
I can wait another 3 years for this heatsink.
Dude people are paying 270€ for a fuckin aluminum box (no disrespect the case is awesome but in the end that's what it is). Cooper + nickel plating + direct touch please.
VLP Ram isn't exactly enthusiast, especially as there are basically no 16 GB DDR4 sticks available. I would just go with standard height (heat spreaders are gimmicks anyway).
I was wondering about why everybody was going for standard ram instead of low profile. Corsair do 32gb Ram (2x16gb) DDR4 3200mhz .... and it is low profile.
https://www.scan.co.uk/products/32gb-(2x16gb)-corsair-ddr4-vengeance-lpx-black-pc4-25600-(3200)-non-ecc-unbuffered-cas-16-18-18-36-x?utm_source=google shopping&utm_medium=cpc&gclid=CjwKEAiAxKrFBRDm25f60OegtwwSJABgEC-ZcsudT_oxmAjhOFpPHUZ67RYIcaCAndDf-sNJDxiiTxoCuoTw_wcB
Not really low profile just standard size
As a very excited Sentry owner-to-be, it also uses a PCIe riser. If your heatsink hung over the PCIe slot, it would prevent us from using the primary 2.5" drive mount, but there are a LOT of other solutions for storage. I would really, really love to see something that's got enough cooling capacity to really stand out from the crowd here.
That's a bit of an unrealistic timeline, I think.I will not Wait 3 years for this Cooler to come out to the market.
I hope you can get it out to this summer or earlier.
Because of the biggest design with AXP-100 is already done and tested.
Ah okay, my mistake. So the only real choices for 32gb VLP ram is CruicalThat are Standard Size not VLP memory.
But its needed of standard size to get it out to the market.
dondon: Will it fit 42mm tall Ripjaw V and 44mm tall TridentZ ram?
Would be nice if you specify what "normal height ram" is.
If you take that large heat sink off, you should be fine. Stick a smaller heat sink on whatever is under there.No z270i compatibility...I'm crushed.
I've been using these to stay compact https://www.amazon.com/Vktech-Heats...8&qid=1487636194&sr=8-1&keywords=copper+shims with tape like this https://www.amazon.com/BCP-Adhesive...&qid=1487636259&sr=8-6&keywords=heatsink+tape
That's too bad. Would be nice if there's a rectangular version using a 92mm fan that's compatible with tall RGB ram and the strix board (though overhanging the PCI-e slot would break too much compatibility). But beggars can't be choosers.I think that means 31mm or so. I.e. no raised heatsink, but instead something like the Corsair LPX or Team Vulcan RAM. Or better yet RAM without any heatspreaders.
First of all for those of you that don't care about sentry, just to let you know some of us might have actually bought the Dan's case and the sentry. Also the bigger the demand for the product the more likely the product will get made, and one of these major companies will back the product.
Also I am willing to pay up to 200$ for the best cooler under 48mm.
Red herring argument. Major companies don't "back" any of these one-offs. They're paid to manufacture, that's all. As long as there is enough bulk, they'll make it, the only thing that would change is the pricing.
This is a thread about the A4, and dondan's suggestion of creating a heatsync was in response to the performance demands of a heatsync placed in the A4.
I think this cooler will be also interesting for Sentry owners. So a bit of compatibility is important.
http://uk.crucial.com/gbr/en/ct2k16g4vfs4266
http://uk.crucial.com/gbr/en/ct2k16g4xfd824a
They cost £330 for 2400mhz and £400 for 2666mhz ....
May I propose the single fan rectangular version of the previous suggestions?
I think the ram clearance will be a turn off for many users. The Nexus/Cooljag can't be used as precedents because their fans were supposed to be put on top, not below.
rectangular with 6 or 7 heatpipes, cooper, full contact, twin fan . yes please!
I don't remember this heatsink being tested. There may not be space to fit a fan below.Dan's seems similar to the PH-TC12LS. Just with mountings on the bottom
Speaking of... Why did this heatsink do so badly in Dan's tests?
I've purchased/backed both. The Sentry will be my Plex server. A4 my gaming machine. Both would prefer good coolingFirst of all for those of you that don't care about sentry, just to let you know some of us might have actually bought the Dan's case and the sentry. Also the bigger the demand for the product the more likely the product will get made, and one of these major companies will back the product.
Edit: seems that it was tested and performed worse than all the other coolers?!
