Finished, haven't ran temps yet. Definitely need to get custom cables for the nest. Very easy to build in. For the fan at the top there is a frame up there don't think you will be able to do to it.
What a beauty. Lucky you!
Thanks! Coming from a sg13 the temps are actually better. Under heaven the 1080 is at 65c. And it's quieter.What a beauty. Lucky you!
Does anyone have a photo of the a4-sfx and the Ncase M1 side by side?
I dont know whats wrong, but i dint see any image. I tried to see it on pc and on phone and still nothing. Can you just post direct link please?
Thank you
Thank you.
Thise cables from PSU look quite messy even with modular psu, so maybe a custom cables can help it.
Question: is there a chance, that you could fit a slim fan on the top above the motherboard? Is there enough space for it?
Edit: like this one: https://www.quietpc.com/kaze-jyu-slim-2000
I sure do, as a part of my very poorly done pictures (was more excited about starting it up) Please note "poorly" also reply to image quality - my apologies.Does anyone have a photo of the a4-sfx and the Ncase M1 side by side?
The corsair cables are hard to deal with in original form.Thank you.
I plan on doing custom, but I was just trying to get the build together. As for a fan I don't think a fan will fit. The space is very limited and the riser card touches the top of the case with its bend. And I wouldnt recommend bending it more. My temps for CPU is 49c on heaven. But I'm rocking a 6500.
and my quick assembly
View attachment 16168 View attachment 16169
For those interested it is:
Asus Z170i Pro Gaming
i7-6700K (undervolted, no hyperthreading)
Cryorig C7
Corsair SF450
G.Skill Ripjaws DDR4 3000
Asus GTX 1080 Strix A OC
And a little old Samsung 850 EVO 1TB
I can certainly see the appeal of custom short cables for the PSU now, but that is a whole new adventure of which I know absolutely nothing.
Stress tests normalised around 79 C for CPU and the short test for GPU around 65 C, but take that one with a grain of salt.
For more real life situations I'm about to fire up some VR fun with Vive and Battlefield 1 - I'll make sure to note temperatures along the way if anyone should be interested.
Cryorig C7
Corsair SF450
Ran some Time spy in 3dmark
Screenshot of EVGA precision showing temps min and max of GPU and CPU.
http://www.3dmark.com/3dm/17773264?
better score that i had with my i7 5930 on the X99 board by a few points pretty happy with the results.
Specs:
MSI Z270i Gaming Pro Carbon AC
i7-7700 (non K)
16gb Corsair Vengeance 3333mhz
EVGA GTX 1080 (ACX cooler)
Cryorig C7
Corsair SFX 600
Samsung 960 Pro m.2 512gb
Samsung EVO 850 1TB Sata
IMO it's more then worth it to buy the tools/parts to shorten them. They come out much better.
Funny enough it popped right in, zero hassle. I must admit that surprised me a bit, as it took some time to get it in the Ncase.Nice build! Did you have any trouble fitting that gtx1080 inside? I just ordered exactly this gpu and i was a little worried about dimensions.
I would not worry at all Jonas Mellkvist.Really interested on CPU and Gpu temps in game as BF1.
Im afraid aftermarket Gpu increase CPU temps
Do you have a link to someone that sells an affordable crimper?
I have a few questions I hope someone can answer.
If not overclocking, is it worth going for the 7700 (65w) instead of a 7700K (91w)? The 7700K is still a higher base clock but considering the Cyrorig C7 is often the loudest part of the system, keeping the CPU cooler would help reduce the fan noise. Even with a GTX 1080, it would seem the 7700 would match it well and the benefits of the 7700K are outweighed by having lower CPU temperature under load.
On the GPU front, which model is the quietest GTX 1080. I was initially looking at the ZOTAC GTX 1080 AMP Extreme however it seems like this card won't fit. I want a GPU which doesn't spin fans at idle, and is relatively quiet under load. It seems like the ASUS Strix may be a good choice, but what other options are out there?
Nearly every review I have read which compares the Corsair SF450 to the SF600, rates the SF450 quieter. Is this the preferred PSU choice since even a 7700K & GTX 1080 won't exceed 450w? I am basing my information mostly on this video:
Are there any plans for the some experienced member of this forum to come up with custom cabling for Corsair SF450/600 such that the MB and GPU power cables are just the right length? Since the Corsair PSU and ASUS Strix Z270i MB are going to be a popular component choice, it should be possible for someone to come up with the exact length necessary for a perfect cabling run. This be very beneficial for the community to just be able to buy a known configuration that would be just right.
Thanks in advance for any information that can be provided.
Yes there will be new productsI have two new project in my mind will start with them after i am done with shipment
Great! Thank you so much for the honest answer Dan. One more thing, lol. Can you say whether the July batch be the V1.1, or a re-run of the V1?Brand new cases. But there will be also a V2 (more a 1.1) of the A4-SFX but only with tiny ajustments.
My eye-balling work fo far... Haven't got my case just yet... (usa)
View attachment 16171 View attachment 16172 View attachment 16174 View attachment 16175 View attachment 16176
seconded!Damn son, great looking work! If you're taking orders, let me know![]()
Has anyone else been looking for carrying bags? I only found a few that were both reasonably priced and fit the case (maybe).
Dimensions: 12.87" (L) x 4.41" (W) x 7.87" (H)
https://www.amazon.com/gp/product/B01E57ZRGK
https://www.amazon.com/Kattee-Canvas-Leather-Vintage-Messenger/dp/B00PXRPV6I/
https://www.amazon.com/Messenger-Camera-Evecase-Digital-Cameras/dp/B01M7USE9A/
https://www.amazon.com/Tenba-636-223-BYOB-10-Camera/dp/B00KT7G9UY/
They rarely list the inside pocket dimensions so it's hard to tell if it will fit or not. I plan on ordering the first messenger bag.
How long is that? 150mm or so? That's about what I was thinking should be enough considering the 24pin plug is right next to the PSU, taking into account bending etc. But cable mod only goes down to 250mm and I'm not super excited about buying stuff to mod one cable...Wish there was a retail solution.
I would recommend looking at camera bag packs instead of messenger bags. They can be more expensive but offer alot of padded protection. Also messenger style bags are more likely so swing or hit into objects if you are in a rush...
ProTactic BP 250 AWIf one finds an appropriate camer-type bag let me know. There was an amazonbasics branded one on amazon at a very affordable price, but it's slightly too small.
Can someone give detailed pictures or instruction on how to connect Dynatron T318 and a fan when using X99E-itx/ac?
I looked through Dan's website, but the tutorial is not clear enough.
