Blackreplica
- May 9, 2016
Do none of you guys live in Germany? I'm sad that no one has posted receiving tracking numbers
The guys in germany are too busy amassing components for their next dan a4 build #jealousAF
]Today I received my DAN Case ;-)
It's a really nice piece of work! Unfortunately I have to wait for the Asus Z270I =(
By the way - I got No. 10 =)
THANK YOU dondan for this amazing work over years!
I hate Germans right now!Probably most of the German backers will receive there case today. My tracking code status: "in Zustellung"="in delivery" !
I received mine today. Such a beautiful thing. Congratulations Dan, what an achievement!
Been following this project since it's inception and backing the Kickstarter was a no-brainer for me. Alas, I currently have no use for the A4, as I will be embarking on a long travel in February. That's why I had contacted Dan about selling my order at the end of the last year, and he gave me the green light. Then I received the update that the case would really ship in January and I decided I want to hold it in my hands just once after all these years.
And it was totally worth it! It's insane how small and light it is.
If anybody is interested in a SILVER A4, send me a pm.
So I would just like to write a few words about the last component I bought for this case. The SF600/SF450 power supply (I have both at the moment).
I tested them yesterday at the place I made my apprenticeship with their professional test equipment and I have to say I am amazed by both power supplies.
For my two units I was able to get the following results:
The SF450 minimum efficiency (20-100% load) was at 20% with an efficiency of 88.5%. At max load (510W) it had an efficiency of 89.8% and the maximum efficiency of 93.2% was reached at 280W.
The ripple of the 12V rail on the SF450 was always bellow 28.7mV and at peak efficiency (280W) it was 23.1mV.
The maximum temperature delta of the heated air to ambient (exactly 21°C) was 9K.
The SF600 minimum efficiency (20-100% load) was at 20% with an efficiency of 88.2%. At max load (640W) it had an efficiency of 88.6% and the maximum efficiency of 92.8% was reached at 330W.
The ripple of the 12V rail on the SF600 was always bellow 27.5mV and at peak efficiency (330W) it was 21.3mV.
The maximum temperature delta of the heated air to ambient (exactly 21°C) was 4K.
I sadly didn't have any good equipment to test noise. The problem was not that I didn't have a sonometer, I had one, I just didn't manage to get the PSU into the small anechoic chamber without disconnecting the electronic load.
Just from listening I would say at 300W (average of their peak efficiency) the SF450 was just a tad quieter than the SF600 but not by a lot.
Bellow 200W both of them were almost silent (meaning that I had a hard time isolating the noise of the test equipment to only hear the PSU).
In conclusion efficiency wise these PSUs are insanely good. The ripple voltage is also pretty good (not quite high-end but definitely higher midrange) and noise wise they are both very quiet. the SF450 being a bit more quiet but also running about 5K hotter.
I personally will keep the SF600 but there isn't really a clear winner.
Great work, this information is goldI got my recently bought SF450 at home, waiting for the A4. Did the SF450 make it all the way up to 510W on the secondary side? That's good to know (Even though it will be close to impossible to be able to draw that amount of power with the A4
Did you check to see how much draw was needed before the fan started spinning?
Could you post a few more pics with Strix box, just for reference?Today I received my DAN Case ;-)
please pst pics of the finished master piece![]()
I don't think it will help in reducing the temps but a 10-12mm thin 80mm or 92mm can fit.
What about one above the psu, and one below where the SSD would go?I dont think its possible to mount one at the top.
1. a 92mm fan doesnt fit there
2. the riser cable will touch the fan doenst matter how thin he is
what gpu cooling type are you using?So here are my results. CPU Temps increased in Games ~ 8°C. GPU about ~5-8°C
The CPU temps didnt really increase in CPU Stress tests, gues the back of the Graphiccard heats the CPU while playing games
What's difference in temperature between the Noctua NH-L9i with A9x14 and the one with the 25mm fan?First impressions on the case,
Well builded ! Looks awesome and its cazy how small it is.
All temperature risen a little bit (testing it at the moment how much) and the noctua with a 25mm isnt as quite as in a normal ATX case. the small gap between the sidepanel and the fan causes a noise
