Does these actually fit? I got one through evg promotion, I haven't don't the measurements but I'm using one currently with my FTW 1080.Damn, would still recommend getting those 90 degree connectors though.
not the evga relocation thing, just a normal right angle adapter.Does these actually fit? I got one through evg promotion, I haven't don't the measurements but I'm using one currently with my FTW 1080.
I'm happy someone did already get the case but I'm a little bit worried about this
Is that yours?
I've had small defects/variations in retail lian li cases before. (Panel not 100% flush with another panel, very very slight curve in what should be a totally flat edge, etc.) I'd expect this to be no different, like any other consumer product. I'm looking at an old Q11 in my entertainment cabinet right now that has a side panel that does not sit flush with the main chassis. Happens.
Yeah, I second to that. Also, I wander if the Corsair SF450 would be enough to handle a Z270 mobo with just one m.2 SSD, a 7700k (with a C7) and a GTX 1080.
Without a doubt. I think you would have a hard time to draw 300W with that setup (non-OC). And then OC isn't something that will be easily done in this case.
91W TDP maximum on a Kaby Lake CPU, 180W TDP on a 1080, and then a few tens of watts for the Z270, RAM and SSD. And it's hard to push them to the limits in "realistic" workloads.
My two cents...correct me if I'm wrong
Should be more than good enough although the 7700k puts out more heat than the 6700k... And pricing is out of whack right now.Yeah, I second to that. Also, I wonder if the Corsair SF450 would be enough to handle a Z270 mobo with just one m.2 SSD, a 7700k (with a C7) and a GTX 1080.
In running a 980ti and I'm pulling ~330 from the wall with the SF600.For reference, my max OC'd 1070 and 6700K at 4.2ghz on all cores undervolted, plus two SSD's and 1 case fan draws about 230 watts in Unigine Valley. Add another ~40 watts for a OC'd 1080.
My 6700k is at 4.6 1.3v and the 980ti is at 150% power limit. Fan barely spins up on the PSU during gaming loads.I have the same PSU. Is your 980 TI overclocked? If so, that looks spot on for full rig power consumption with a similar setup as mine.
that's called a shroud and each board being different means youd have to make you own. and dan did temp testing, reviewers probably will too as the case start getting into their hands. the videos that are out now id call more of a preview than a review. you've been following the thread long enough to know this...
The 6700k (4.6 1.3v) throttles under Intel burn test but the OC is still stable and the CPU maxes out at 67 under gaming load so I don't think there's a reason to go L9i or anything like that.
Stock Ivy Bridge cooler.c7 cooler?
I would jump up to an SF600 so that the fan never really kicks on, but thats based on your budget.Is it realistic to expect silence from setup made of this components (without setting my house on fire)?
6600k non OC
Cryorig C7 (or something similiar available in Italy or Hungary)
Strix Z270I mobo
ASUS Strix 1060
Corsair SF450
And when I say silence, I really mean silence. I'm currently running system on Z170-A board, in spacey mid tower case with LC-CC-120 CPU fan @670rpm (212 EVO equivalent), case is under desk, ~70 cm away from me, and it is really non audible. I can barely hear CPU fan when I open the case, while PSU and GPU are 0db.
CPU temp is ~32C, GPU ~40.
So, is it possible to expect something similar from C7 (with case being 1m away from me on the desk), just with higher temps? I really don't mind higher temps, as long as they don't cause home fire
The SF600 will be total overkill and not be any quieter, I think that's a complete waste of money - the SF450 is already off most of the time anyway!I would jump up to an SF600 so that the fan never really kicks on, but thats based on your budget.
6600k non OC
Strix Z270I mobo
ASUS Strix 1060
Corsair SF450
nope just sick of dumb shit around here and not holding my tongue as much as I used to. sounds like you are a little over sensitive if you took that as condescending and abrasive. sorry was that too harsh too?!Thanks for not only your condescending attitude, but also regurgitating to me much of which I already know without providing a single shred of useful information. Your contribution and attitude are indicative of abrasive personality issues (or perhaps a severe lack of manners), but I'm sure you're numb to observations like this by now.
But the temperature of the PSU is used on the load by design, so if you're going for basically a completely silent system, a higher wattage PSU means that there is less heat generated and thus the fan will not spin up.The Sf psu Fans are temperature controlled.. my sf 450 doesnt even turn on the fan @ 160Watt loud
look through my past postings, theyre polite, very little attitude and a lot of help. until very recently when ive become sick of all the bullshit around here. noobs not doing a little searching and asking the same things over and over, one person making suggestions then acting like its the end of the world if they don't get exactly what THEY want, the constant internet knowledge pissing contests etc etc.
sorry aboot that
sorry aboot that
I've got my SF600 sitting right next to me, my 7700K on the way ($329 right now on antonline at ebay for those of us in US), plus 16GB of 3000mhz Team Vulcan RAM ($70 @ Jet.com) and 1TB m.2 MX300 ($249 Newegg flash deal) en route. Just waiting to get the mobo (either MSI or Asus at this point), and sweat over whether I just say "fuck it" and buy a Titan X or wait until whenever the Ti comes out. I have already decided I'm not "settling" for a 1080. And no offense to anyone with a 1080, it's a great card. I'm just intentionally going over the top for this build.
I feel a creeping dread that there is no way in hell I will be able to wait until I get my hands on a 1080Ti (taking into consideration how crazy it is on release, even assuming I can wait that long), and instead I am going to spend $1200 on a card that may get outclassed, price to performance wise, just weeks after I get my hands on it...
Settle for a 1060 or RX 480 until the release of the 1080ti, then sell the RX480 on Craigslit, Reddit, or other avenue of your choice.
00joshua00 I tested it 8 month ago. The cables are too thick to fit behind the motherboard. In this time I also posted a picture here.
Not with that CPU and the c7, no. At least not under load.Is it realistic to expect silence from setup made of this components (without setting my house on fire)?
6600k non OC
Strix Z270I mobo
ASUS Strix 1060
Corsair SF450
When I had the c7 on my 3570k (StOCK, delidded/ relidded) it got way too loud for my tastes under gaming loads. If you don't already have the CPU is recommended getting a 6600t instead
The c7 cooled fine, but it was loud. Which is what hajzenberg was asking aboutI think this is hard to believe. I currently have the i5-3570k running under a Noctua NH-L9i without any case at all. Both coolers should perform more or less the same. I am currently running the CPU at 4,3 Ghz with 1,20V. The temperatures never rise above 90°C. at 4,1Ghz and 1,07V I barely hit 70°C. I don't see why you should have such huge problems with your C7 at stock settings in the DAN A4..
