7700k test
noise : c7> l9i+nf a9pwm
I will just leave this here
Picture of 8 palettes
Dan said that in the end 15 palettes fitted in the garage and one was going into the shipment room
https://www.computerbase.de/forum/showthread.php?t=1279570&page=105
I count 4x4 cases per layer, 7 layers, and a total of 16 pallets (only 8 pallets on the picture though)...but the end result is the same, 1792 cases! Yay!Looking at the arrangement, there are 8x4 per layer x 7 layers total. That's 164 DANcases. If I'm correct, 8 pallets would be 1792 cases! That means all of the Kickstarter cases are there!I thought you were only getting 500?
Since I am waiting for A4 and haven't purchased any components, took the saber case as well.
Just now backed it in Indiegogo.
how did you just now back it on indiegogo?
You should be fine with both. The GPU shouldn't heat up the middle metal spectator much anyway.Should I be worried about the back m.2 slot on the Asus Z270i in terms of thermals with the video card back up against the back of the mobo? Hm. I have 2x m.2s. 1x 950 and 1x 960. If the thermals in the back slot are going to throttle either of them, I'm selling the 950.
Thank you very much for summing everything up nicely.cooler test conclusion
k cpus
want performence
1. c7
2. lp53+a9 14t
3. l9i + a9 25t
want silence
1. l9i + a9 25t
2. lp53+a9 14t
2.1 c7
non k cpu
1. l9i + axp100 120mm fan adapter+ darkrock tf bundle fan(135 x 135 x 22 (120mmhole))
2. thermaltake engine 27
3. l9i + nf b9 or a9 low rpm adapter
For that price, take it, it's still an i7, you won't really notice much difference between than and newer Intel CPUs, they simply haven't improved significantly unfortunately. I run a 2600K i7 with a Cryorig C7, it works perfectly fine at stock, it's quiet enough, so I am sure the Noctua will be great too.Dear A4-SFX-"Activists",
my colleague is selling his old rig and I am considering to buy it for my A4-SFX. I would kindly ask for your opinion.
i7 3770K
16GB DDR3-1600 Corsair Vengeance
Gigabyte Z77n ITX
He is asking for 250€ - what I consider cheap looking at ebay.
Main Use:
HTPC with SteamOS
Some Gaming (Civilization, Emulators, maybe DeusEX ...)
Watching movies
The A4 will be hooked onto a video projector in HD. Not interested in overclocking. I planned to purchase a GTX 1070 for it.
My Questions:
1. Can I get it quiet?
2. Better buy a kaby lake i5 or new AMD instead?
3. Is Noctua nh-l9i a good option if I don't overclock?
Thanks for your time.
Joe
I purchased a gigabyte ga-z77n myself off Ebay 2 months ago since I had to get an ITX motherboard, and still wanted to keep my trusty 2600K![]()
It is a freaking steal for that priceDear A4-SFX-"Activists",
i7 3770K
Gigabyte Z77n ITX
Main Use:
HTPC with SteamOS
Watching movies
My Questions:
Joe
I would totally buy off your friend since z77 ITX boards are rare and still carry a lot of value. The i7 shouldn't hold you back either, but you definitely won't be able to OC on the L9i as it already runs hotter than the newer chips.Dear A4-SFX-"Activists",
i7 3770K
Gigabyte Z77n ITX
Main Use:
HTPC with SteamOS
Watching movies
My Questions:
Joe
what are you talking about?Because it is/was available in indiegogo to back.
link?
this case isn't ... if someone is "selling" it .... it is a scam
"this" case I am talking about is Sentry.
Pretty sure he just meant that he ordered both cases.so off topic. there is topic for that case. please go there to post about it.
Hey all!
Thought i'd create an account and let you know this.
I've been nagging caseking.de for some time now, about timeframes, pre-orders etc.
Yesterday they let me know that the case is available for pre-order!
It isn't available on their website yet, they made me order some special version of the H440 (249 euro's) which hasn't been released yet, and they will change the order manually to the A4-SFX.
I haven't received word yet on any delivery date, but it's getting closer!
I can confirm this too; they directly volunteered the exact same instructions to me.
The problem is, I don't see any way on their site to ship to the US.
What reseller(s) ship to the US?
Pv
This isn't correct. I made the picture nerly on halftime.In total I have 15 pallets and one extra with spare parts. Every pallet was 8 layers in height. I had to remove the top layer because it was too high for the garage. Also your case count for every layer is wrong.
