Could you look into the Vantec Tornado 92mm? I know it's loud but seems insane the amount of air it pushes.If someone wants to source and/or send me a Silent Wings 2 92mm, I'll happily add it to the comparison list![]()
That seems like a bit much, also it's a 38mm fan which is a no go for this case.Could you look into the Vantec Tornado 92mm? I know it's loud but seems insane the amount of air it pushes.
Looks like 25mm fan or less since 48mm of clearance, right?That seems like a bit much, also it's a 38mm fan which is a no go for this case.
1. It's memory max height it's 52mm, not 54...Cant wait for the results guys the memory max height says 54mm yet cpu max height 48??? How much space is there to the exact mm!
So the Noctua B9 is better than the A9 (25mm version?) Isn't the A9 a newer model, that comes with the rpm limiter cord thing to make it quieter anyway?
I'm at the point that I'll sacrifice temps for noise, so honestly I think that is not even worth going to an aftermarket fan on the L9iLooks like 25mm fan or less since 48mm of clearance, right?
How about Delta AFC0912D-PWM, seems like it can push the most air at that size
That is an idea worth looking in to.Very nice to hear, just ordered some small wifi antennas to prevent having bunny ears.
Just some cheap ones from aliexpress I'm afraid. Just wanted to give everyone here with nice long antennas a heads up. Depending if your motherboard has the connectors properly aligned there shouldn't be much of an issue but mine has the wonderful engineering that puts them above one another making one antenna stick out hence the bunny ears.That is an idea worth looking in to.
Could you please share a link of what you are getting?
just in time! just bought my final components and put it together yesterday, went with the low noise reccomendations and have the combo l9i+b9 redux, duper quiet, but i think i made an error getting the silverstone 600w sfx power supply, i may be a bit picky but its by far the loudest component in my setup.
I think this or something to this model could have been used on the cases power switch??
What do you guys think?
[/url][/IMG]![]()
thats the best post of 2017 for me.Guys, tomorrow will be Christmas for me, because I will get 16 palettes full of something you are waiting for![]()
BRING IT!! MY BODY IS READY!!!
LOL. I have no idea what you're into, but this is hilarious.
Finally, great news! I'm so in for this.
Have the C7 and the Noctua L9i with the 25 mm A9 at home.
Too bad the fan of the C7 was broken and the replacement is on its way. The cooling was good/okayish but I couldn't lived with the noise of the faulty fan. As soon as the new fan arrives I'll let you guys know.
In the meantime I bought the Noctua with an aftermarket A9. Running at 940 rpms it's really silent buuut my 3770 (@4.1 ghz / -0,1v offset) is reaching 60-65 degrees celsius in Overwatch (FHD, maxed out, 150%, 60fps). I will adjust the fan curve in the following days to see if I can reach better temperatures without having much noise. Besides that the A9 can be a PITA. At around 1300 rpms I'm starting to really dislike the noise and at 1600 rpms I think that my tower is preparing for a flight...
I need to add that I'm really sensitive with noise... I hope it's possible to get the DAN case as silent as possible so that I enjoy living and playing with that rig!
And after that, you will be our Santa Claus.Guys, tomorrow will be Christmas for me, because I will get 16 palettes full of something you are waiting for![]()
Any idea when the case will be available for non kickstarters ?Guys, tomorrow will be Christmas for me, because I will get 16 palettes full of something you are waiting for![]()
