dondan
- Apr 15, 2013
Z170 is only interesting if you plan to overclock your cpu.
S4 Mini is as small as you can go with ITX, and that's already out. I imagine the next step after those is likely something involving custom PICMG 1.3 backplane-SBC combos. I imagine something could be done like fitting a GPU blower-style cooler onto a half-length one and putting it and a GPU back-to-back, with an HDPLEX PSU underneath the backplane. Or something like that, I don't know, that's just what I was thinking about this morning.about 11 years ago the LianLi PC-A05 thread started, it was the most popular case thread in [H] (I'm still using what I call the 2nd version from it)
6-7 years ago (?) then things started to get smaller, lots of threads... Q08, Q25, PC-V354, FT03-Mini, Sugo SG05 , Bitfenix Prodigy, Silverstone SG09/SG06, Cooler Master Elite 130, etc
then we wanted to go smaller but manufacturers didn't offer lots of options so the NCASE M1 thread was created 4 years ago (title was Aluminum SG05 evolution by Lian Li)
then DAN-A4 idea was born 3 years ago
waiting for the next step
the op in the a05 thread:
I just cancelled immediately after watching the video.Bummer that they require cc to sign up for the free week.
In a week.Will it come out on his main channel?
Well alright, I watched a couple more of Linus' videos first. THEN I cancelled.
You can even watch it the whole week for free after you cancel.
I have, at the same time, asked them to delete the account.
I kept my first free week even after I cancelled. I cancelled the second free week yesterday, and I can still watch the videos today.They actually immediately cancel your free week when you cancel the subscription, so you only have until you decide to cancel that. You don't get the remaining time in the free week
you must be blind or didn't look. its one page back and only on a paid/free trial site...Can someone post a link to the review?
I must be blind, because I can't find it.
should be on YT next week.
edit: or someone turfed the link... look on LTT 's vessel page.
EVGA cards have their own LEDs I have GTX 1080 SC, you can adjust it to all colors of the rainbowNice, seems quite tight. No place to add LED with this one
Linus managed to assembly a EVGA GTX 1080 Classfield inside the A4-SFX.
I guess that was not the real review by Linus, but merely a sample build "in small cases"?
Look what I found..
Look what I found..
Was disappointed with Linus recommending a blower-style GPU. Apparently he doesn't understand that the EVGA open air coolers (dual fan) are quieter and cooler due to more air movement at lower fan speed, shorter fins (aligned perpendicular to the log axis of the card, means that heat transfer from fins to air is more efficient as the difference in temperature between the air and fins should be on average higher) and not having to blow most of the hot air through that tiny restricted exhaust area.
That's true if the card is placed the way it's exhausting hot air to the inside of the chassis which is not what happens with A4-SFX.Why would you be disappointed with blower-style gpu? In a case without fans it is the best possible solution.
Nope, an open air cooler gpu can be of benefit in this case due to the proximity of the fans to the vent on the side of the case.Why would you be disappointed with blower-style gpu? In a case without fans it is the best possible solution.
Here card takes fresh air from the outside, heats it up a bit, fraction of a degree and exhausts it through the top of the case.
Using open air coolers is a problem with cases that let the card recycle hot air inside the case.
Any chance we can get a custom glass side panel for this case so we can see the whole motherboard or gpu?
Jeeez prava, you always can twist someone's words...
I was of course talking about an open air card that has fans so there is airflow induced by those fans.
Any companies that can do this for you if you provide the measurements?Sure, if you make it yourself.
Jeeez mother of god. You seem to imply that air magically gets out of the case. Without fans being part of it. Also, you imply that air gets heated up "a fraction of a degree" which couldn't be further from the truth. Heck, have you tested your enclosure at all with open-air coolers? Cases with no fans are forced to recycle hot air all the time because, well, there is nothing making that air get in or out of the case. You only have to test your own case to see what happens when you use non-blower cards inside cases that have no forced airflow inside. Just go and find a 290X non-blower and play for several hours straight. Monitor the temperatures of every single component of your case, and the case itself, then panic.
I'm worried that a case designer and seller is making such statements. Have you done any thorough testing whatsoever? Because I'm starting to think that you haven't. Or else you wouldn't be making such claims.
OK.
Put a 250W card, non-blower inside. Play for a few hours while monitoring the temperature of the your components and case itself (ie put a probe on the case itself). Enjoy. So many of you have yet to try high-powered gpu cards in small enclosures. It seems you will find out about the truth the hard way.
What makes it worse is that, somehow, you actually claim that blowers are worse. I have no idea how could you ever get to that conclusion. You couldn't reach it testing, because testing will yield completely different results.. so, how?
I was talking about the same scenario. Case with no fans, gpu card with fans. How could I talk about a gpu without fans? There aren't any unless you go sub 75W. I'm not talking about that.
You just try your case with a 290X (or 780 TI or 980 TI... or any high-powered card that is over 200W) open-air card. Play several hours. Then tell me how roasty everything is. You just have to test it. Nothing else.
