Deal on woot.com 06/08/09
Asus Eee PC 900 Netbook with 1.6GHz Atom Processor
1 Asus EEEPC900A-WFBB01 8.9", Atom N270, 4G SSD, 1GB DDR2, Linux, 802.11bg
Features:
* 8.9” screen size for more-than-ample viewing space, making it more comfortable on eyes when in use
* 1024×600 resolution allows you to view a single A4 page without the need to scroll left or right for easier reading and editing of documents
* Built-in Solid State Disk (SSD) technology ensures that the internal drive stays quiet, draws less power, boots up faster and resists physical shock
* Robust data protection and superior shock resistance, ideal companion for reporters, wildlife photographers and other outdoor enthusiasts
* Incredibly intuitive point-and-click user interface that even first-time PC users will find extremely easy to use
* Fast boot up, get onto the Internet in mere seconds from the time you press the power button
* Open Office, Skype, and 50 other applications preinstalled
Specifications:
* Operating System: GNU Linux
* Display: 8.9” Display, 1024×600 resolution
* LCD Type: LED Backlit
* Intel CPU & Chipset: Intel® Atom N270 1.6GHz
* Hard Drive: 4GB Solid State Drive (SSD)
* WLAN: Built-in 802.11b/g
* Memory: DDR II 1GB
* Display Card: Intel UMA
* Audio: Hi-definition Audio
* Stereo speakers
* Built-in Mic
* Storage Cards: SD/ MMC (SDHC)
* Battery: Li-ion Battery, 4 hrs of operation under normal use
* Power: Output: 12V, 36W; Input: 100-240V AC, 50/60Hz universal
* Dimensions: 8.86" (W) x 6.7" (D) x 0.79" ~ 1.33" (H)
* Weight: 2.20 lbs (with Battery)
* Case Color: Pearl White
* ASUS Exclusive Utility: Super Hybrid Engine; Eee Connect; Dr. Eee
Input / Output:
* 3xUSB
* MMC/SD(SDHC) Memory Card Reader Slot
* VGA-out (D-Sub, 15pin)
* Earphone jack (3.5mm Audio Out)
* Microphone (3.5mm Audio In)
* RJ45 10/100 Mbps LAN Connector
Additional Photos:
* Keyboard and Touchpad
* Left Side Profile
* Right Side Profile
In the box:
* Eee PC 900A Netbook
* A/C Adapter and Cord
* Rechargable Netbook Battery Pack
Features:
Specifications:
* Stereo speakers
* Built-in Mic
Input / Output:
* 3xUSB
Additional Photos:
* Left Side Profile
In the box:
