I would like to change the heatsink in my Silverstone TJ-09 case and of course that means disconnecting all cables and wires from the motherboard and sliding out the motherboard attached to the motherboard tray and then removing the motherboard = royal PITA.
Does anyone ever cut an access hole in the Silverstone motherboard tray so that there is easy access to the under-surface of the CPU area of the motherboard making it an easy job to change a backplate for a different heatsink? Is there a reason NOT to cut an access hole for potential future changes of heatsinks and required different backplates?? [too bad an access hole cannot be cut without unwiring and removing the motherboard and I don't have the time to do all of that, preferring to be using my computer and not wasting time making mods that IMHO should have been engineered in the first place]
Frankly, with such an excellent case, I cannot help but wonder WHY Silverstone did not engineer the motherboard tray with such a hole.
Thanks
MikeSp
Thanks
MikeSp
