Like the example below, with a couple of modifications if you don't mind using shortcuts (you can create the shortcut in the same script using more code). There doesn't seem to be an easy way to apply the same trick directly on the ISO. You could do it manually, but you'll still need to convert the jpg to an icon format. Icons are icons, not arbitrary pictures in any format you want.Sorry if I wasn't clear. I want to apply any thumbnail jpg to my iso files (they are movie iso's and want the thumbnail to be of the movie's dvd cover).
You could always write a shell extension to do that to an ISO which can contain just about anything. I'm sure a lot of people would love that. There's always software behind something cool.Well, thumbnails will automatically display for jpg & pdf. I can't image it can't be done for any file...
