Custom built my own desk...
Discussion in 'Gaming & Office Furniture' started by Etherton, Jun 2, 2018.
  1. Etherton
    Etherton Will Bang for Poof
    6,825
    Aug 7, 2006
    Some time back I went to Office Depot and bought one of those glass L-shaped desks. Initially it was OK but I ended up hating it. Shopping around I never really could find anything I liked that wasn't ridiculously expensive. Good Lord, office furniture gets crazy expensive if you do not want the pressed sawdust stuff. So, I built my own and am really happy how it turned out. :D
    (Yes, I am a huge MCU fan)
    I wanted a wall to wall desk - 8 foot total length. Built the frame out of 2x4s and 3.5" screws.
    Once leveled, I used 4" Lag bolts with washers to secure it to the studs.
    I don't have a photo but there is a 1/2 sheet of plywood covering the frame before the next step.
    We went down to Lumber Liquidators looking at hardwood flooring. Ended up buying a single box of BELLAWOOD 3/4" x 3-1/4" Select Brazilian Koa Prefinished that someone purchased to much of. Originally, $144 per box and the manager sold it to me for $20. Not too shabby!
    Laid it all out for a "test fit"
    The overhang here is intentional.
    Cut the pieces as needed - once cut they really do not need glue or nails.
    RGB Lighting added for the overhang and front of the desk. I have a Phanteks case that has the RGB controller so I attached it to that. Added a dimmer and a switch up under the desk to turn it off all together if needed.
    Ordered some Acrylic Rod Clear Extruded - Square. I then took a dremel tool and sanded/scuffed some texture into them. Some fine grained sandpaper afterwards to finish frosting the finish.
    Tucked the lighting in between the desk and the flooring. Made an extension and ran it back to the computer. Tested the lighting to make sure everything was going to look and work as expected.
    Started gluing and clamping the front Koa to the desk with Liquid Nails.
    Still need to silicone the Acrylic Rods into place.
    Ran the extra lighting up underneath the table for additional glow.
      File size:
      220.4 KB
      0
      File size:
      333.5 KB
      0
      File size:
      115.2 KB
      0
    The Mad Atheist and zerogg like this.
  2. wra18th
    wra18th [H]ardness Supreme
    7,771
    Nov 11, 2009
    Very nice! Good job!
    Etherton likes this.
  3. Etherton
    6,825
    Aug 7, 2006
    Thanks!
    Also, attached my Tripp Lite surge protector up underneath the frame of the desk. Looks like a mess but it isn't - way better than it was before! Still working on the USB hub.
    Ordered these grommets to drop the wiring.
    Some finished photos:
    Comixbooks and tungt88 like this.
  4. SeymourGore
    SeymourGore 2[H]4U
    2,647
    Dec 12, 2008
    Really nice job, makes me feel a bit ghetto to be using a dining room table as my personal desk.
  5. ItWasMe
    ItWasMe n00b
    38
    Jun 21, 2018
    Definitely have some desk-envy going on now. Excellent job and nice score on the flooring, looks amazing. The lighting is a nice touch too!
    Has me mentally planning one for myself.
    Kudos!
    tungt88 and Etherton like this.
  6. Wotok
    Wotok Gawd
    757
    Oct 23, 2000
    Mount one of these under your desk! I have one wall mounted in my little comms closet.
    amzn.com/B00NUDAP54
  7. Aehs01
    Aehs01 [H]Lite
    101
    Apr 12, 2007
    Looks awesome, makes me wonder if I should hit up that guy I know who does wood working.
  8. IdentityCrisis
    IdentityCrisis Limp Gawd
    144
    Oct 29, 2012
    Great desk. Like the use of hardwood flooring for the desktop.
