ctrl_z in MS Office 2016
Discussion in 'General Software' started by colore, Mar 12, 2016.
  1. colore
    colore Limp Gawd
    384
    Sep 18, 2010
    hello!
    how can I assign the ctrl_z to undo stuff in MS Office 2016?
    I cant BELIEVE they removed the most important keyboard shortcut!
    thanks!
  2. Skripka
    Skripka [H]ardForum Junkie
    10,792
    Feb 5, 2012
    It does undo...
  3. colore
    colore Limp Gawd
    384
    Sep 18, 2010
    when did I say it does NOT do undo?
  4. Snowknight26
    Snowknight26 [H]ardness Supreme
    4,192
    May 8, 2005
  5. colore
    colore Limp Gawd
    384
    Sep 18, 2010
    I never said there is no UNDO
    I said that there is no UNDO with CTRL+Z!!!!
    can't you read people?
  6. Skripka
    10,792
    Feb 5, 2012
    I read just fine. I typed and then hit crtl+z. And it undid what I did.
    Are you pressing crtl+z correctly?
  7. colore
    colore Limp Gawd
    384
    Sep 18, 2010
    for me it doesn't work
    and yes I press ctrl+z correctly (it works in notepad)
    why it doesn't work in my brand new 2016 MS Office installation? what can be wrong?
  8. MrTroy03
    MrTroy03 Limp Gawd
    422
    Feb 12, 2008
    Ctrl + Z is undo in Microsoft Office 2016. Do you have some kind of special F key or function lock on on your keyboard that modified the Ctrl key? I would bet $38 that Ctrl + Z undoes your last action.
  9. colore
    colore Limp Gawd
    384
    Sep 18, 2010
    how can I troubleshoot that? how can I check that ctrl_z is actually binded in my MS office?
  10. gimp
    gimp [H]ardForum Junkie
    10,014
    Jul 25, 2008
    Do other hotkeys work?
    eg, ctrl+c and ctrl+v for copy and paste.
    Or is it only ctrl+z that's broke?
  11. colore
    colore Limp Gawd
    384
    Sep 18, 2010
    only ctrl_z is broken!
  12. MrTroy03
    MrTroy03 Limp Gawd
    422
    Feb 12, 2008
    Try a different keyboard man, maybe your keyboard is messed up.
  13. colore
    colore Limp Gawd
    384
    Sep 18, 2010
    I have a laptop! And it works otherwise fine! There must be some MS Office setting! where can I find the keyboard shortcuts?
  14. MrTroy03
    MrTroy03 Limp Gawd
    422
    Feb 12, 2008
    OK I did a bit of Googling for you, apparently you aren't alone. This may have something to do with language settings.
    "At last after a lot of searching on the Internet I found the solution:
    You must select English as the default keyboard language (control panel -> regional settings -> keyboard).
    If you select a non-English language as the default keyboard language and open Microsoft Word a lot of shortcuts will change to IBM Common User Access mode (e.g. Ctrl+C will change to Ctrl+Ins and Ctrl+V will change to Shift+Ins)
    Note that if you set English as the default keyboard language everything will still work even while you're switching your keyboard language to type non-English text.
    Note: For Windows 10 the above option is found under Control Panel -> Clock, Language, and Region -> Change input methods (under Language) -> Advanced Settings (on the left) -> Override for default input method.
    SOURCE: Shortcut keys don't work in MS-Word on Win8
  15. MrTroy03
    MrTroy03 Limp Gawd
    422
    Feb 12, 2008
