ctOS Tower 27 (modded Tt View 27) by SimpleModz
Discussion in 'Worklogs' started by alexciobanu, Mar 23, 2017.
  1. alexciobanu
    alexciobanu Limp Gawd
    317
    Apr 12, 2015
    Hey guys,
    Yet another case mod from my, I'm working on 3 at the moment.
    This one is in the Thermaltake View 27 case. Iit will be Watch Dogs 2 themed and I'm calling it ctOS Tower 27.
    I did an overview of the case a few months back. You can check it out below:
    SPECS
    Case - Thermaltake View 27
    CPU - Intel Core i7 6700K
    MB - ASUS Sabertooth Z170-S
    RAM - 4 x 4GB Kingston HyperX Predator 3000MHz DDR4
    GPU - NVIDIA GTX 1070 Founders Edition
    SSD - 2 x 240GB Kingston HyperX Savage
    HDD - Seagate TBC
    PSU - Thermaltake Thermaltake DPS G RGB 650W
    Custom cables & lighting - CableMod
    Water Cooling - Thermaltake
    I'll start this one as well with some photos of the case:
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Thanks for checking it out and stay tuned for more!
    Cheers,
    Alex
  2. alexciobanu
    317
    Apr 12, 2015
    Hey guys,
    Here's the first update :)
    I made a cut out in the PSU shroud and added some acrylic cover panels. Next step is to add all the graphics.
    The cut out will serve to illuminate through the bottom acrylic panel once the graphics are applied.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Cheers,
    Alex
    Emission likes this.
  3. alexciobanu
    317
    Apr 12, 2015
    Hey guys,
    I have some pretty cool hard tube fittings to show you :)
    The Thermaltake Pacific RGB fittings!
    I did a video on these a while back and only getting around to using them now.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Thanks for checking it out and stay tuned for more :D
    Cheers,
    Alex
  4. alexciobanu
    317
    Apr 12, 2015
    Thermaltake Riing Plus RGB fans and Tt premium riser cable!
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Stay tuned for more!
    Cheers,
    Alex
  5. alexciobanu
    317
    Apr 12, 2015
    Hey guys,
    I have an update on the work I've done on the fans and SSDs. This will give you more of an idea for the theme and the vinyl that I'm using :)
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Cheers,
    Alex
  6. alexciobanu
    317
    Apr 12, 2015
    As the fans and SSDs, I added a similar skin to the ASUS Sabertooth Z170S motherboard :)
    BEFORE
    [​IMG]
    AFTER
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    And same with the pump/res combo :)
    [​IMG]
    [​IMG]
    [​IMG]
    Stay tuned for more guys :D
    Cheers,
    Alex
    Derf likes this.
