Cerulean
- Jul 27, 2006
NUMBER ONE
Photoshop CS4 on my machine takes like 45 to 60 minutes to open a 48MB PSD (of a web template; Photoshop uses about 1.5GB of memory for this file), and now to my discovery it seems to be taking approximately that long to open a simple 4MB PSD I just freshly made and saved (it happens to be the PSD for the animation below; Photoshop uses about 150MB to 250MB for this file).
I have my scratch disks enabled on all my drives and partitions in this order (according to Photoshop Creative Feces 4) :
D:\ - 195.98GB
C:\ - 5.91GB (same HDD as D:\; 500GB SATA-II Seagate Barracuda 7200.11)
E:\ - 41.76GB (different 200GB IDE HDD)
Available RAM: 1677 MB
Ideal Range: 922-1207 MB
Let Photoshop Use: 1459 MB (87%)
History States: 25
Cache Levels: 8
Enable OpenGL Drawing: Yes
Vertical Sync: Off
Force Bilinear Interpolation: Off
Advanced Drawing: Yes
Use for Image Display: Yes
Compositing: Gamma Corrected
Color Matching: Yes
NUMBER TWO
I make an animation...
Really simple. I set the delay to 0.01 (and have tried 0.00) on all the frames except for the very last frame, which is 5 seconds. In the "Save for Web & Devices" preview and configuration window, it plays just fine and normal. Problem? Well, as you can see -- the exported animation above obviously isn't using those frame delays (except for the last frame). The frame delay used there appears to be between 0.1 and 0.25, which is NOT what I want. I want 0.00 or 0.01 -- it's supposed to swoop and come in fast, and hold it for 5 seconds on the last frame.
THIS IS HOW I FEEL ATM
D:\ - 195.98GB
History States: 25
Cache Levels: 8
Vertical Sync: Off
Color Matching: Yes
NUMBER TWO
