retardedchicken
- Nov 5, 2003
I finally got my MSI motherboard to go along with my 3200+Venice and got Windows up and the chipset/sound/video/ethernet drivers up and all that good stuff. Then I re-downloaded steam and CS:S. I downloaded it all and fired it up, and got into a game. As soon as I joined the [H]ardgaming server a grenade went off, and the only sound I heard was from my center speaker (using Logitech Z-640s by the way). Right before I got on I was listening to Winamp with a 5.1 channel audio plugin and I could hear sound from all speakers clearly. Then I decided to look directly at a firefight, then turn real quick. Sure enough, when I was looking at the fight I could hear the sound clearly only through my center channel and sub, but when I turned the sound immediately cut out when it was supposed to come from my side and rear speakers. Anyone have a similar occurence? It cannot be the board since in the CP the speaker test it identifies all speakers correctly. The CS:S sound test would only play sounds out of the center channel and sub. I'm installing UT2K4 as we speak to see if it is the same for all games or just CS:S. What could the mix up be?
EDIT: UT2K4 gives me proper audio
