Did you know there is an in-game MP3 player built right into Counter Strike: Source? If you want to listen to music while ingame, but not mess with other programs, and have better control, then this is for you.
Instructions:
1. Type mp3 in the console to bring up the music player.
2. Click on Options ---> Add Directory
3. Navigate to your music directory. You can just add the top directory, and you will be able to navigate through subdirectories. Your My Music directory works fine.
4. Look through all of your folders, and right click and select "Add To Playlist" on any song you want to play.
5. After adding all of the songs you want, click on the first song in the playlist. Then click on "Play".
The songs will play in the order you have selected. After each round ends, it will also change songs. When somebody talks using the in-game mic, it will lower the volume of the music just slightly. You can also adjust the volume using the slider bar on the mp3 window. Shuffle also works.
Instructions:
