Crytek Releases Hardware-Agnostic Raytracing Benchmark "Neon Noir"
Discussion in 'HardForum Tech News' started by Sabrewulf..., Nov 13, 2019.
  1. Dayaks
    Dayaks [H]ardness Supreme
    7,378
    Feb 22, 2012
    Since 1080p is 2megapixels and 3440x1440 is 5, that sounds about right. Also sounds like it scaled nicely.
    I have to try this benchmark.
    Someone earlier said reflections looked blurry. Personally I think games so far with RTX reflections are too good. I’d rather more FPS and more blurry reflections (probably closer to real life...).
  2. auntjemima
    auntjemima [H]ardness Supreme
    5,317
    Mar 1, 2014
    I mentioned blurriness... but if you looked at my card I am running a 760gtx lol
    Krazy925 and Dayaks like this.
  3. thesmokingman
    thesmokingman [H]ardness Supreme
    5,357
    Nov 22, 2008
    Holy carp, it's 1gb for the engine and then the freaking bench is another 4.4gb?
    Anyways...
    1080p
    GameLauncher_2019_11_16_19_21_54_060.jpg 5760x1080p GameLauncher_2019_11_16_19_27_33_006.jpg
  4. Ricky T
    Ricky T Limp Gawd
    160
    Nov 7, 2019
    I finally decided to run the benchmark and damn this thing looks great. Too lazy to post screenshots but I ran this with a 2080 Super and 9900k.
    1080p Ultra-12474
    1440p Ultra-7744
    blandead, cybereality and GoodBoy like this.
  5. IdiotInCharge
    IdiotInCharge [H]ardForum Junkie
    12,435
    Jun 13, 2003
    Very impressive for a software only solution.
    The part I find interesting is that Crytek may be able to find ways to use RT hardware to better 'inform' their software / shader solutions to come up with a way to use RT hardware to improve visuals without impacting performance as much as using RT hardware directly.
    Armenius likes this.
  6. prime2515102
    prime2515102 [H]ard|Gawd
    1,530
    Mar 3, 2003
    1920x1200 (CPU is currently at 4.8Ghz)
    Edit: My bad, that 7221 I posted must not have been on Ultra, but something is amiss with this benchmark:
    CPU @ 4.8Ghz:
    CPU @ 5Ghz (and I'm 100% sure it's not throttling):
    I tried this 3 times and 4.8Ghz was higher every time. WTF? :confused:
  7. TMCM
    TMCM [H]ard|Gawd
    1,381
    Apr 15, 2003
    Glad to see your system bench well since mine is comparable.
  8. prime2515102
    1,530
    Mar 3, 2003
    See my edit... lol
  9. Auer
    Auer Gawd
    1,014
    Nov 2, 2018
    RTX 2070, 1440p. Realized I had Sharpening and Gsync on so turning them off netted a small gain.
    If it was a game, it would be totally fine by these results. FPS is not very consistent tho, Lowest was 47, highest touched the 90's.
  10. Lakados
    Lakados [H]ard|Gawd
    1,784
    Feb 3, 2014
    Its a cool demo and all but like all benchmarks I need to see it in an actual title first for it to have context I mean just looking through the posts I see a score of 6000 which yields 60fps and another just shy of 10,000 which again seems to yield 60fps at the same resolution. So I look forward to somebody releasing a game using this because it would probably be beautiful, yet sadly I don't know of any titles coming out that are using Cryengine ont he horizon.
  11. FrgMstr
    FrgMstr Just Plain Mean Staff Member
    48,517
    May 18, 1997
    The 60fps you see on that screen has nothing to do with the score.
  12. Lakados
    Lakados [H]ard|Gawd
    1,784
    Feb 3, 2014
    Thank you for the clarification.
    FrgMstr likes this.
  13. cybereality
    cybereality [H]ardness Supreme
    4,874
    Mar 22, 2008
    On my 5700X I was getting well north of 60fps at 1080p, usually around 80-90 and some places jumping to over 100.
    Auer likes this.
  14. Algrim
    Algrim [H]ard|Gawd
    1,572
    Jun 1, 2016
    ASUS laptop with i7-7700HQ and GTX 1070: 4774
    Auer likes this.
  15. prime2515102
    1,530
    Mar 3, 2003
    For the hell of it I re-ran this at 1080p for comparison sake (last time was 1200p).
    My results were very inconsistent before so I cooked my GPU with Furmark until the temp stabilized at 76C and the GPU clocks stabilized at 2037Mhz core, 5454Mhz memory (not too shabby for an Armor OC with the stock cooler).
    I then opened the benchmark (which, oddly, bumped the core clock up to 2050 ???) and set it to 1080, ultra, fullscreen, then alt-tabbed to Furmark and closed it, and immediately went back and clicked start benchmark. It was a lot more consistent this way.
    That was on the 3rd run.
    1st: 7256
    2nd: 7054 (dunno what happened there)
    4th: 7263
    So... yay? lol
    P.S. I'm running 1/2 the memory now too in single channel - RMA happening soon.
  16. Thunderdolt
    Thunderdolt Limp Gawd
    277
    Oct 23, 2018
    Just checking in: Is there a version which doesn't require the installation of a wholly unrelated app in order to launch the app that launches the app? Or should I continue to ignore this?
  17. prime2515102
    1,530
    Mar 3, 2003
    You can launch it without the launcher, but you need the launcher to download it.
  18. XpediencY
    XpediencY Gawd
    682
    Jan 12, 2008
    1440p
    Auer likes this.
