Hi guys
I purchased a 19" Nec Multisync Fe991sb in February of this year from Newegg and I noticed that it has developed 10 vertical dark lines in the middle of the screen that are readily apparent when the background is white or light colored. Is this normal? I read the owners manual and it said to open a white window with the contrast and brightness turned up and it would go away in a matter of minutes but after leaving it that way all night while I slept I've noticed it made no difference - I've since tapped the monitor on the side and they've disappeared - is this normal with this type of monitor?
