Crossover or Patch Cable ?
Discussion in 'Networking & Security' started by cwolf78, May 1, 2007.
  1. cwolf78
    cwolf78 Limp Gawd
    456
    May 7, 2005
    I am installing a CAT5 wall jack that will be fed from my router... what type of network cable do I need to use between the router and the jack ?
    Thanks !
  2. jvlazzar
    jvlazzar [H]Lite
    107
    Sep 26, 2006
    a patch, or straight-through cable. they are used to connect unlike devices, ie computer > router. a crossover is used to connect like devices, ie router > router, switch > switch.
  3. Xeth
    Xeth [H]ard|Gawd
    1,624
    Apr 6, 2007
    Doesn't matter, all ethernet ports are auto-sensing now. (but patch cable would be the correct answer)
  4. cwolf78
    cwolf78 Limp Gawd
    456
    May 7, 2005
    That's what I needed to know ... thanks ! :D
  5. Voltron
    Voltron Limp Gawd
    137
    Mar 9, 2006
    It does matter.
  6. unix_foo
    unix_foo [H]ard|Gawd
    1,326
    Jun 21, 2002
    Technically.. computer to router you need a crossover. But I know you are talking about a switchport on a router w/ builtin switch.
  7. YeOldeStonecat
    YeOldeStonecat [H]ardForum Junkie
    11,330
    Jul 19, 2004
    Without knowing what's on the other end of this wall jack.....it's impossible to answer this. "Probably" a straight cable...but again..without knowing...I mean, someone could have done something screwy on the other end...we're all probably "assuming" that it does to a standard patch panel, and/or switch....but without knowing....it's all just a guessing game.
    Combined with most newer hardware is all auto direction sensing...just plug it in until you get link lights. :p
  8. KaosDG
    KaosDG [H]ardForum Junkie
    11,944
    Apr 3, 2000
    Or, your wiring contractor may have hired sub-par wiring monkeys who wired half your jacks as 568b and punched them to the wall panel in a random spread of 568a, 568b, or just plain... "whichever color i grabbed first"
    :mad: :mad:
  9. WesM63
    WesM63 2[H]4U
    3,266
    Aug 29, 2004
    Yea.. I hate people that do that. Just happened today while installing a new VOIP/IP Telephony system. In one office the phone would not come up but when I plugged the cable directly into her PC it worked fine..scratched my head and checked the ends on the cable, sure enough someone had put a x-over cable from the wall plate to the pc. It worked fine, but wouldn't work fine for my PoE IP Phone.
    Like my dad always says, "If your going to do something, do it right the first time"
  10. Sharaz Jek
    Sharaz Jek Gawd
    647
    Jul 19, 2000
    only gigabit ports do this.
  11. J-Mag
    J-Mag 2[H]4U
    3,640
    Dec 21, 2004
    Huh? I've seen 10/100 routers with autosensing ports.
  12. WesM63
    WesM63 2[H]4U
    3,266
    Aug 29, 2004
  13. k1pp3r
    k1pp3r [H]ardness Supreme
    7,881
    Jun 16, 2004
    Yay for color blind cable guys!!
  14. Diablo2K
    Diablo2K [H]ardness Supreme
    6,599
    Aug 10, 2000
    You can't assume someone will have hardware with autosensing ports, you got to wire the job right. All lazy people do is cause more work for everyone else!
  15. MavsX
    MavsX [H]ard|Gawd
    1,086
    Jan 4, 2007
  16. movax
    movax 2[H]4U
    3,676
    Aug 12, 2005
    Very true; luckily all my hardware is auto MDI/MDI-X (the switch running the ports in the house is, which is a *huge* plus luckily), and most modern network stuff is...I think.
  17. cwolf78
    cwolf78 Limp Gawd
    456
    May 7, 2005
    I will be plugging in a DVR system that will hook to my DSL/Cable router...
