Okatis said:Does anyone know if this monitor supports DDC/CI.
1.) What is the native resolution of the monitor exactly? If it supports 4k @30hz, will running the display in 2560x1440 make the monitor look not as good as a monitor whose max res is 2560x1440?
2.) Can you purchase an aftermarket adjustable stand for this monitor?
Most monitors support DDC/CI, I guess I can try the software out. Reducing the contrast also reduces the brightness but degrades the color quality the more it is reduced.
That would great if you have the time. Often at night I set the brightness lower so my eyes don't bleed, being able to adjust it would be godsend![]()
