I just purchased 3 1080p monitors for an eyefinity or surround setup.
I currently have a P5Q-E motherboard (775 P45 chipset) It supports crossfire but only at 8x/8x pcix. I found this http://www.hardocp.com/article/2010/08/25/gtx_480_sli_pcie_bandwidth_perf_x16x16_vs_x4x4/ At least with the 480s in SLI there was less than a 10% difference between running 16x16 and 8x8. I found another article that said it was 5% or less difference in 6870s but I can't seem to find the article now.
The [H] article was looking at 3x 1200p monitors so my resolution will be slightly smaller. I'm wondering if 2 6970s would experience the same 10% or less difference that I've found in the articles? I honestly don't want to put in the money for a complete system upgrade right now. I have a Q9550 which is running @ 3.65 stable and have seen from game benchmarks that I wouldn't gain much from going to sandy bridge.
From what I've seen, going crossfire at a 3 monitor resolution can give HUGE gains in fps. I'm just wanting to make sure that my setup would not be wasted due to running them at 8x pciexpress. Can anyone confirm if my board really can only do 8x8? For one card it is able to do 16x.
I've read about the sound coming from a crossfire setup but have also read that if you leave space between the cards that is diminished. I looked at my board and should at least have one pci slot of space between the 2 cards. I'm using a case with good airflow and can mount a fan on the side of the case blowing right between the cards so that should not be an issue.
Here is my system specs if that makes a difference
P5Q-E mb
Q9550 cpu @ 3.65
8 gigs of ram
2 hd (no ssd yet )
1 dvd rom
BFG ES 800w power supply
currently nvidia 260 gtx
I asked in the power supply forum and they said my power should be fine but wanted to include that here in case that may be wrong.
Any help would be appreciated.
P5Q-E mb
Q9550 cpu @ 3.65
8 gigs of ram
2 hd (no ssd yet )
1 dvd rom
