Critique this build for 4K Gaming
Discussion in 'General Hardware' started by I3eyond, Aug 15, 2017.
  1. I3eyond
    I3eyond Gawd
    934
    Jan 14, 2006
    4K Gaming
    Prefer $1,500, but can do $2k - Tax/Shipping not included
    North Carolina
    CPU, Mobo, RAM, Storage, PSU, Case, CPU Cooler, Windows
    N/A- Keeping rig in sig for other purposes, possibly to sell
    6) Will you be overclocking?
    100% No.
    Will be getting a 4K Freesync down the road. However, for now, 1080p 27".
    October
    9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
    Something that will do Crossfire and lose no bandwidth, 2-way
    No- Will be getting Win 7 Pro 64-bit
    PC Hound:
    https://pchound.com/tiVM5A/
    No GPU listed because I already have a Vega 64 on the way. The reason I went "all out" on PSU is so that if I want to add a second Vega 64 down the road I can.
    I'm not familiar with modern hardware (CPUs in particular at all, so critique away:)
    Thanks for the advice.
    Best,
    I3
  2. manny1222
    manny1222 Gawd
    719
    Mar 11, 2012
    I'm no expert, but my critiques would be
    1. You can save money with just one 2x8gb kit of memory. If its just gaming, you don't need more than that.
    2. There's also really no point of having 2 SSDs (I'm assuming for Raid0). It makes more sense to have one and at a 2 or 4TB HDD
    3. Even if you add a second RX Vega, I doubt you'd need a 1600W PSU for it. I believe a 1000W PSU that is half or a third the price of that one you have listed will work just fine.
    4. If you're spending this much, why not invest in a better CPU cooler? I know you say you don't want to overclock, but you never know.
    My 2cents
    FrgMstr likes this.
  3. manny1222
    manny1222 Gawd
    719
    Mar 11, 2012
    Here's the same parts list with the changes I mentioned. Total is closer to you $1500 preferred budget.
    Even with two RX Vega added, the wattage is 810. I selected a platinum 1000w PSU, but you could go up to a 1200W gold PSU for about the same price if you really want more wattage. I used pcpartspicker because PC Hound wasn't reporting the wattage with the GPUs.
    https://pcpartpicker.com/list/WvdMkT
  4. I3eyond
    I3eyond Gawd
    934
    Jan 14, 2006
    As a side note, off-topic, nonetheless, how would the rig in my sig fair with 4K gaming, or even 1080p, when I add the Vega 64?
    My mobo only has PCI 2.0, and I'm rocking a 1st gen i5-760 (not OC'd) with 8GB RAM. My current GPUs are (2) 660ti's in SLI. For example, with BF1, I can only play @ 1080p at around 30-40FPS TOPS.
    The only reason I'm considering the system overhaul is because I feel for 4K or even 1080 gaming, the rig listed above and in sig will significantly bottleneck the Vega 64. If it won't, I'll just save $1500! LOL
    Thoughts?
    Thanks!
    -I3
  5. manny1222
    manny1222 Gawd
    719
    Mar 11, 2012
    I dont know the answer to that question but I'll say if you're not in a hurry, you can wait for Coffee lake to be released in a couple of months so you know you have the latest, or you benefit from the price reduction it will bring to Kaby Lake.
    I3eyond likes this.
  6. I3eyond
    I3eyond Gawd
    934
    Jan 14, 2006
    Good advice, thank you!
  7. manny1222
    manny1222 Gawd
    719
    Mar 11, 2012
    And while you're waiting, you can test to see if there's a bottleneck. :-D
    I3eyond likes this.
  8. Daleon
    Daleon Limp Gawd
    250
    Nov 1, 2004
    Yeah no reason to buy an Intel chipset at the end of its life. If you were going Ryzen AM4 that socket will be around for a while. Intel always uses a new socket for new chipsets.
    Buy an OEM Windows key for <$20.
    If you were building today, with no OC and as much future proofing as possible I'd go this way:
    https://pchound.com/Z6SYLM/
  9. bjornb17
    bjornb17 [H]ard|Gawd
    1,978
    Oct 17, 2003
    Wow. That is a terribly designed computer. First of all Vega, especially only one of them, is not going to get you a good 4K experience. Also don't expect a good 4K experience unless you overclock. You don't need a $450 1600W power supply - get a 1000W for $250 or less. The system in my signature uses a Corsair 1000W PS and is overclocked balls to the wall and the power supply is still overkill. Maybe consolidate into one hard drive. RAM is okay (and i do highly recommend 32 GB) but you could probably find faster sticks for that price. CPU and motherboard are fine although end of life - you could by a 5.0GHz+ rated 7700K on silicon lottery and configure it per their specs if you have an aversion to overclocking yourself. Consider using a AIO cooler as well. Sell or return your Vega, it is too slow and hot. With the money you get buy a 1080ti, or maybe two of them. Good luck :)
    I3eyond likes this.
  10. I3eyond
    I3eyond Gawd
    934
    Jan 14, 2006
    Thanks for your honesty :) ~ I've been out of the loop for quite some time, as my rig is nearly 7 years old now.
    I bought into the hype on the Vega 64 and clicked order the second the SKUs popped up on Newegg; it will be here Thursday. Unfortunately Newegg has a no return policy on them, just return for exchange. So, I'm stuck selling it which I really don't want to go through the trouble of doing.
    Likewise, looking at benchmarks for the 1080TI, wow, it really knocks the Vega 64 out.
    I MAY stick the Vega 64 in my current rig to see what kind of performance boosts I get on BF1 & Overwatch @1080p. Hopefully my computer won't be TOO much of a bottleneck and I can actually play both games (particularly BF1) at max settings and have 60+ FPS.....
  11. bjornb17
    1,978
    Oct 17, 2003
    What newegg's "policy" is and what they will do are two different things. Don't open the box, just chat with newegg and they'll usually grant an RMA anyway and sometimes even give you a prepaid label. Using a 1080Ti will save a lot of money on electricity in the long run as well. With your budget and smarter choices you could definitely have a 5 GHz, 32GB, SLI 4k rig no problem. When I get home I can try to configure a system for you that works better.
    I3eyond likes this.
  12. I3eyond
    I3eyond Gawd
    934
    Jan 14, 2006
    Alright, thanks!
  13. manny1222
    manny1222 Gawd
    719
    Mar 11, 2012
    I dont agree that he needs 32gb od RAM if this is just a gaming rig. I dont believe there's been any documention of a game using more than 16gb. I would understand if RAM was cheap and there was only a small price difference where you'd say "might as well", but that is not the case. Getting 2x8gb still leaves that room for upgrade when games begin to use more ram or he starts ro use more ram intensive applications. But as of right now, there is no need.
    Again, my 2cents.
  14. bjornb17
    1,978
    Oct 17, 2003
    My resource monitor was reporting 18 GB of use yesterday while playing BF1 and nothing else running in the background :) The more RAM you have the more it will use. If he needs to cut money anywhere, RAM is the place to do it, but if he wants a good 4K experience he will need all the resources he can get.
    People keep saying games don't use more than 4C/8T or 16 GB of ram but my system proves otherwise.
  15. bjornb17
    1,978
    Oct 17, 2003
    Here is a start. Needs a little refining but just wanted to throw this out there. M.2 drive will make things faster. I only added one video card to build... once you return your VEGA you can buy a second!
    https://pchound.com/Qj5UPB/
  16. horrorshow
    horrorshow [H]ardness Supreme
    7,375
    Dec 14, 2007
    This is one of the few times where I'll say: "Wait a few months."
    Why pay $350 for a 4c/8t i7 Kaby Lake now, when you can buy a 6c/12t i7 Coffee Lake for the same price in just a couple months?
    I3eyond likes this.
  17. manny1222
    manny1222 Gawd
    719
    Mar 11, 2012
    From what i hear, it may be better to sell than return the RX Vega if he was able to get it at launch day price. There's rumors that the price will go up, and I'm miners will also be buying. He could make a little money selling it back.
  18. Skillz
    Skillz [H]ard DCOTY 2017
    22,042
    Aug 14, 2004
    That PSU is a stupid buy for that system. It could handle 4+ GPUs with ease and you "might" use 2 instead of 1? A 550W PSU would be more than plenty for 1 GPU and an 850 - 1000W would be enough for 2 GPUs. I've got 3x 980 Ti running on a 1200W PSU without any issue and it gets used, heavily.
    https://www.hardocp.com/article/2017/08/14/amd_radeon_rx_vega_64_video_card_review/16
    Under the most extreme case the entire system used ~500W at the wall. Adding a second GPU wouldn't double that power.
  19. rhansen5_99
    rhansen5_99 [H]ard|Gawd
    2,032
    Nov 12, 2001
    I would say the 7700k is a pretty good CPU that if you plan on overclock to 4.8ghz plus will serve you well. I would suggest a 2x 16 GB ram lot if you really want 32gb, and as suggested a m.2 nvme ssd, maybe the Samsung 960, also the 1600w PS is over kill for sure and if you actually use that wattage on a typical 15a circuit you can have problems in the house. As far as GPU the 1080ti appears to be a better price performance part, but the Vega 64 might be better if you have a freesync 4k monitor. Personally I would add a large mechanical drive if you need storage for steam.
    As for your i5 760, these are probably 40% the IPC of the Skylake chips clock for clock so if you can OC to plus 4ghz you might actually get a good gaming experience so definitely worth a shot. Side note on the 1156 socket you might be able to find one of the i7 or Xeon 4c8t chips for a bargain on eBay to get a little extra out of the platform with hyper threading.
  20. rhansen5_99
    2,032
    Nov 12, 2001
