Im working on a website for my studio. Let me know what you think so far, Ive got the nav bar done ... thats about it really.
http://www.madcoww.com
yah...and i also love how sarchasim is lost on youOriginally posted by Excavator
Don't you love people telling you to work on the content or that the links don't work? It's obviously a work in progress.
Originally posted by chevy4x4trucks
I would suggest doing it as a widescreen since monitors are more wide than tall that way you have more room to work with. If you make your flash file 780x468 you can fit it comfortably in an 800x600 resolution.
Originally posted by pistola
I got streaming to work, you have to encoded the video to stream. For instance if you have premeire, open you clip in premeire, drop it on the timeline. Go to File>Export>Adobe Media Encoder. A new window will open up and you'll have the formats to use, I always use Quicktime. Then you can change the settings, like framerate, size, datarate, keyframeing. Then you re-render it out, and the quicktime will now stream.
