magictoaster
- Apr 6, 2005
Whenever I start Crysis, there is a really crazy squeaking sound coming from the video card (BFG GeForce GTX 260 OC Maxcore). I've contacted NCIX for an RMA, but this morning I found this on the inCrysis forums :
"You have VSync disabled.
With VSync disabled the movies and load screens (and the main menu before the world is loaded/rendered) will be rendered at the highest possible FPS. What you are hearing is the GPU generating 2500-4000 FPS and the accompanying squeal from the electrical components--likely the Voltage Regulators--struggling to accomplish this and maintain an even load.
Most other games have a cap on movie and menu FPS which prevents this massive overworking from happening.
Enabling VSync will make this go away with Crysis (and Warhead)."
Does this make sens? I'll try it tonight and see if this works, but I find this very strange. My "old" 8800GTS did not do this at all...
