Crazy networking problem - will paypal five dollars for the fix.
Discussion in 'Networking & Security' started by phatmonky, Jan 16, 2005.
  1. phatmonky
    phatmonky n00b
    32
    Jul 16, 2004
    NOTICE: PROBLEM HAS BEEN SOLVED
    I posted this on one other site as well, so you are in competition for this HUGE sum of money.
    Problem:
    Computer won't resolve domain names.
    Can ping IP's. Can't ping domain names. Can connect to other computers on local network.
    Background:
    Machine is my father's. It used to have an odd internet sharing program on it to go through another machine for internet connection. The machine is since setup on a network with a standard router/DHCP server. Nothing fancy.
    I can't get out to any websites.
    What I've done so far:
    First I uninstalled the old program and removed all registry evidence of it.
    I reinstallaed the NIC.
    I tried static IP and manual setting of DNS servers
    I did an XP repair.
    I changed network cards.
    I tried an XP repair again with the new NIC. Repeat the above with new NIC.
    ipconfig /flushdns does nothing
    ipconfig /displaydsn shows a localhost address of 127.0.0.1 like it should, however a ping of the localhost tells me it is 0.0.0.1
    When trying to go to google.com in IE, it says "connecting to site 0.0.0.1".
    I can ping google's IP but can't ping "google.com"
    tracert for google does times out. doesn't make it to even the gateway.
    HOSTS and LMHOSTS file is clear, and in fact the localhost IP in HOSTS says 127.0.0.1
    Still, after all of this NOTHING. Still can't get out.
    So I come to you for help. Just start throwing out things I haven't checked, a utility to download, anything.
    I'll check back later. Thanks!
    Normally I would just wipe the machine at this point, but there is a program on it that I don't have the original install for and would be a serious pain to have to find again. More so than formatting. So at this point, we'll say that isn't an option.
  2. DoMeHardR
    DoMeHardR Limp Gawd
    227
    Oct 16, 2002
  3. SJConsultant
    SJConsultant 2[H]4U
    3,600
    Jan 14, 2004
    First make sure there is only *ONE* hosts and lmhosts files on the system.
    Second, is IE configured to use a proxy? If so, remove the proxy configuration information.
    Third, have you tried removing and reinstalling TCP/IP?
  4. Dr.Evil
    Dr.Evil 2[H]4U
    3,142
    Jul 5, 2000
  5. phatmonky
    phatmonky n00b
    32
    Jul 16, 2004
    please PM me your paypal address so I can meet my end of the deal!
    I came across winsockXP in my search for an answer yesterday, but just passed on it assuming it were just another obscure 3rd party software.
    I know better now in the future. Thanks! :)
  6. Dr.Evil
    Dr.Evil 2[H]4U
    3,142
    Jul 5, 2000
    no problem and yhpm
  7. Alias
    Alias 2[H]4U
    3,417
    May 24, 2001
    Wow man where were you when this happened to my Grandmas PC? I just resorted to useing the USB side of her cable modem.
  8. slowbiznatch
    slowbiznatch Gawd
    856
    Oct 24, 2001
    hehehehehe.... ;)
