I'm having an issue that is really bothering me. I'm running Crashplan to backup roughly 3TB of data, most of which being my RAW photos. According to tech support, the software is designed to stop at 1TB. The workaround that they gave me, was to enter "java mx 2560, deauthorize, restart" into the code to open it to unlimited.
While that is fine, it can be a pain in the ass, especially when I restart after doing updates, etc. The software is supposed to run on restart, and it doesn't. Which means not only do I have to start it, I have to enter the code, restart the software and login again, then run it into the tray. When I run the software, if I don't run the code right away, it will crash before it finishes the system scan.
I have tried reinstalling the software, but that hasn't helped. Does anybody have a solution to keep the code embedded?
Thanks.
Thanks.
