I'm having an unknown issue with a computer...when idling, with no background services or programs running, it jumps between 40-60% CPU usage in the task manager Performance tab. Under Processes, System Idle Process is at 99%, with nothing else showing up that isn't part of the operating system. In normal use, it acts like its doing something else so I'm betting the Performance tab is more correct than the Processes one. Scanned for viruses and ad/spyware with nothing showing up. Anyone know of anything else to try?
The processor queue is a bit higher than it should be at 2-3 nonstop, never dropping below 2
The system is a Duron 1GHz with 768MB ram, external video, sound, etc on WXP Pro/latest SP and hotfixes
edit:
diagnostic startup doesn't help
edit:
