Thanks I'll take the SteelSeries Arctis Nova 7P into consideration, is there any difference between the 7/7p/7x version besides color?
not sure but thats what it looks like.Thanks I'll take the SteelSeries Arctis Nova 7P into consideration, is there any difference between the 7/7p/7x version besides color?
Also what's people thoughts on the audeze maxwell? I'm wondering if I should spend the extra money and get them? I'm more of a music listener than gamer.
Sorry for changing my price range, I was hoping someone here has them and could give an honest opinion on them. I think on reddit people say they had quality issues with them but on youtube reviews people seem to love them.not sure but thats what it looks like.
that is rtings #1 headset, its over $100 than you stipulated so i didnt suggest it.
dont listen to reddit, listen to rtings. MavericK has a set, i think, maybe he can chime in...Sorry for changing my price range, I was hoping someone here has them and could give an honest opinion on them. I think on reddit people say they had quality issues with them but on youtube reviews people seem to love them.
Yeah, I have the Maxwells. I really like them, they are kind of heavy but they sound great. Have basically replaced all my other headsets other than my lighter BT ones that I take with me on trips (Sony WH-1000XM4).dont listen to reddit, listen to rtings. MavericK has a set, i think, maybe he can chime in...
Thanks for the reply, I see Rtings has the Logitech G PRO X 2 Lightspeed rated the best Upper mid-range gaming headset I think it's between those two.Yeah, I have the Maxwells. I really like them, they are kind of heavy but they sound great. Have basically replaced all my other headsets other than my lighter BT ones that I take with me on trips (Sony WH-1000XM4).
Some people have said they have issues with build quality. I haven't noticed any, but I also don't use them as much as some people probably do, so it's hard to say. They don't seem cheaply-made to me, though.
I can't say as I've never used the Logitech G Pro. But I would wager that planar magnetics are going to have better sound. I've used a lot of headphones, and these have really nice clarity and bass compared to most others.Thanks for the reply, I see Rtings has the Logitech G PRO X 2 Lightspeed rated the best Upper mid-range gaming headset I think it's between those two.
How much better would you say the Maxwells are over Logitech G PRO X 2 Lightspeed?
I ended up getting the Xbox/PC ones because it came with an Atmos license. But you can also buy the license for $15, so it's not that big of a deal.I've tried a dozen well reviewed headsets and finally fell in love with the Audeze Maxwell. PS5 version is my choice YMMV
as far as i can tell, it literally is just the logo colour.Will the PS version work with PC or do I need the xbox version?
Yes very well and as mentioned you can buy the THX licenseWill the PS version work with PC or do I need the xbox version?
I know and I did mean $200usd but then I said I was considering spending the extra money for the Maxwell's.ooohh so you only had 200 canuckistani pesos. when people see $200 here they assume its USD, it is a us based forum....
