I have this motherboard with an i7 920 on it, but it looks like i will get (given or very cheap anyways) an i7 970.
The Asus website says that CPU is supported, but even the i7 920 i have does not overclock much past 3.3 with it, and I have a feeling it will "just about work, but dont expect much OC" The cpus both have the same TDP, but as we know that is not how much power it actually uses, just the thermal design of the CPU package.
I was thinking i need to get something a bit newer, with beefy power regulators, I am hoping to get close to 4GHz
I have a 720 watt corsair PSU, and nothing too fancy in the video card department, just a single Nvidia quatro 4700 (might upgrade it to one of the newer mid end gaming card, but only a single card, so m-atx is ok).
Cooling is a Corsair H50 with push-pull fans, it works well when folding the i7 does not go over 65-70c depending what core you look at. (but if i have to change that for the new CPU, no problem.
Storage is just an SSD for OS and 1TB HDD, everything else is kept on NAS
Any recommendations?
Over the last few years i have bought Asus and Gigabyte motherboards, i like both of those brands, but i might be persuaded to get something else.
