PatchRowcester
- Sep 2, 2012
Hello all,
I was wondering if you all give me your opinion on this build. This is almost exclusively a gaming build.
http://pcpartpicker.com/user/patchrowcester/saved/sBGhP6
The components listed here are the ones I need. I have the GPU, PSU and DVD drive to install windows.
I have some questions for you guys as well -
1. The motherboard any good? I currently have a gigabyte motherboard, and it has worked very well for me, so I decided to go with this one.
2. Should I go with Windows 7 or Windows 8.1? I am going to be using this computer for gaming.
Thanks.
Thanks.
