Apathy
- Oct 29, 2004
Last night i was just screwin around on the pc as usual, suddenly it shut off and would not turn back on. the motherboard still has power to it. i can see it posting its codes. tried unplugging everything except power from the back.
the psu smelled really hot and sorta burny. let it sit overnight, no change.
the motherboard reads 0.1 (which reads "expand the Xgroup codes locating in physical address 1000:0") when the power is plugged in. when i press the button to try to turn it on, the code cycles to 2 (which is not listed in the manual). it then switches to 8.2 which reads "1. call chipset power management hook" --- "recover the text font used by EPA logo (not for full screen logo)" and then "3. if password is set, ask for password".
after that, nothing happens.
im assuming this is the psu gone bad? luckily corsair has a 5 year warranty if this is the problem.
i have a 470watt enermax PSU in my old pc that i am thinking of moving over to replace the 620watt corsair.
anybody know if that psu will be able to handle the load of my new pc?
see specs in sig. the new pc is on the left side.
thanks for any help in advance.
