I want to add some USB powered LED strips in my case. I don't want to route wires externally, I am using the few USB ports on the back of the case that I have. Internally, the USB header is being used by my cooling pump and the USB 3.0 header internally has a USB header for my mouse.
My PSU sits at the front of the case, its the tiny Corsair SF600.
My question is, is it possible or does an adapter exist to use one of the peripheral connection directly out of the PSU to a USB header? Any reason I shouldn't plug directly into the PSU? I could make said adapter myself and maybe put a resistor in line to reduce power spikes?
Any input would be helpful.
