Corsair Obsidian Series 800D
My humble effort :)
System Spec:
Corsair Obsidian 800D Corsair
Supermicro X8DAi Rev2
Intel Westmere X5680 CPU's
HX1000 PSU
12GB DDR3-1333 Non ECC
32GB Intel Extreme SSD
2x 2TB Western Digital Sata Drives
2x XFX ATI 5970 Black Edition Crossfire
Watercooling Spec:
HWLabs SR-1 360 X-Flow
HWLabs SR-1 240
Heatkiller CPU Blocks
EK FC5970 GPU Blocks
MIPs RAM Freezer 5 Blocks
Laing DDC Pumps
XSPC Dual Bay Pump/Res
Various BP Fittings & Grills
Touch Screen TFT
Reeven Fans
excellent work as usual
Final System Specs:
CPU: Intel i7 980x @ 4.6GHz 1.435 Vcore - 24/7 OC - temps never go above 68c
Mobo: EVGA x58 3 way SLI E760
Memory: Corsair Dominator DDR3 3 x 2GB 1866MHZ running at 1952MHz
GPU: 2x EVGA GTX 480 HC FTW @ 886/2125 - 24/7 OC - temps never go above 45c
PSU: Silverstone 1500ST
HD's: OCZ Vertex 60GB SSD's, 2 x 150GB WD Raptors
Cooling: Apogee XT block, Black Ice GTX 360, Black Ice GTX 240, Black Ice GTS 360, Swiftech 665 & 335, Swiftech GTX 480 EVGA Water Blocks
Monitor: Dell 24" 1920 x 1200
Case: Corsair Obsidian 800D
Final System Specs:
:eek::eek::eek:
I finished my build in my new 800D last weekend. I'm pretty happy with it for now, it even does OK on air until I get all my parts together for water. I only have one major gripe, and its that the hot swap bay power connector is retarded. Why did corsair put it backwards so that a 90* power connector would have to come from the front side not the motherboard side? This lead me to using a regular SATA power connector on it (I'm using corsairs AX850 btw) and breaking the connector clean off because the regular one is too tall to fit under the neat little cover. Terrible design.
Other than that, happy with it! Now to get down to water cooling. Sorry for the terrible pics, my droid X camera sucks.
I was debating on getting a corsair carbide 400R but just sprung a little extra for the 800D.
^^ two posts up, how do you like that lian li 5.25 120mm bay fan? I think I would spray paint black over the logo for a cleaner look.
The bay is great for adding an additional intake fan to the case. The stock Lian Li fan was bit lacking in the CFM department so I replaced it with a Scythe S-Flex "G" fan.
I don't mind the Lian Li logo. Really doesn't take away from the look when you see it in person. To me, the LG drive and it's logo is far worse offender due to its plasticky exterior. I wonder if there's any optical drives with black brushed aluminum housing in the market...
