I fully expect a live stream.
Oh right. That's what I meant.
Somebody was a little anxious . I imagine most of the cases won't be arriving until Wednesday.
Can you post photos? If it's not too much trouble, that is.
Would you guys recommend waiting for this case, or just going with, say, the 650D? I'm still waiting on Amazon to give me an ETA but they still don't have a clue x_x.
Thanks for the pics. Are the front 3.5" cover panels actually warped or is it just the camera?
YOu mean 5.25" cover? Dunno whats going on in that picture. im holding the cover in my hand now and it doesn't look like that. Crappy camera.
Re: magnets vs nubs. I assumed magnets would be used here. Disappointed hearing that. Small details matter.
The front uses four metal posts to act as pivots/latches. This wouldn't be possible easily with magnets, because we wanted the door to be openable from either side of the case without having to switch out any hardware. The posts won't wear down, but after a few thousand uses, the plastic latches on the door might flex a bit. Which is why there are extra plastic latches included in the accessory kit, in case that piece is broken or flexed too much.
To be completely honest - I think this is one of my favorite cases we've made. It's got a good look, very clean design, and it's exceptionally quiet.
We did a lot of testing with different foam types, some denser, some lighter, and what we felt was the best wasn't the densest or cheapest - it was what we ship. Which is fairly dense, but not exceptionally heavy, foam. The additional noise damping we got from going to a denser foam was unnoticeable, and anything lighter definitely got louder.
Having tested this against all the other "silent" cases we bought, I can tell you we didn't stop development until we beat them on noise levels AND cooling.
Hey Ruffy, two things:
1. Do you think it would be easy to remove the silver bezel for the IO area and paint it black?
2. Pretty keen on putting a 240 radiator at the front of the case (and the top) where the hard drive cages are. What are your thoughts on moving the hard drive cages back (or at least just the bottom one)?
Thanks in advance mate.
1. Do-able. You have to remove the top cover, which thankfully is held on by screws. 8 screws for the top cover from the looks of it.
2. Nope not gonna work, the fans sit flush with the hard drive cage. Now if you remove both trays yes. You could mount a drive in a 5.25 bay with an adapter though.
Also I thought we could move the harddrive bay to be by the psu? for the life of me I cant figure out how.
Lastly to Redbeard, There is some space above the 5.25" Bays for a redesign try to put a card reader up there or something Or figure out a different\hidden route for the front panel wires.
Damn i would snatch this case up in a second if it had a window and a black front IO port :/
This case is still pretty big for a mid tower. It's larger than my P180 (wider, but shorter by 0.5")
My main concern and again I've only just glanced over the case is the back outside panel doesn't secure snuggly. Even after 'clicking' into the mechanism it still has a large amount of play and there doesn't appear to be anyway to secure it using thumbscrews like I have seen on all my previous cases. Maybe once I get some cabling routed behind the motherboard it will provide enough pressure to secure the panel and hopefully prevent rattles. I hate rattles they drive me nuts and I instantly became worried seeing this.
Ruffy, how much of an upgrade do you think the 550 is over the P180? (that's the case I'm using)
