HardOCP News
[H] News
- Dec 31, 1969
CORSAIR®, a world leader in enthusiast memory, PC components and high-performance gaming hardware today announced the immediate release of its new Vengeance LED series of performance DDR4 memory. Unmistakable thanks to its brilliant LED-lit top bar and aggressively styled aluminum industrial design, Vengeance LED is optimized for maximum performance on the latest Intel® X99 and 100 series motherboards. Available in both red LED and white LED variants, Vengeance LED lights up performance PC builds with bright integrated lighting designed to make your PC look as good as it runs, alongside blistering performance at frequencies up to 4,333MHz. Vengeance LED’s stunning LED-lit top bar sets it immediately apart, providing the perfect mix of eye-catching brightness and aggressive styling. Available with either red or white LED lighting, each Vengeance LED DIMM’s LED top bar pulses to create an eye catching display. The result is a fantastic aesthetic designed to complement a wide variety of mid-range and high-end motherboards, graphics cards, and CORSAIR’s full range of cases, liquid CPU coolers, fans and power supplies.
Beneath the LED lighting Vengeance LED is the culmination of CORSAIR’s 20 years of DRAM experience. Each module is built using a ten-layer PCB for better signaling and uses carefully screened ICs for superior overclocking and reliability on the latest Intel® X99 and 100 series motherboards. Vengeance LED’s signature aluminum heat spreader ensures rapid heat dissipation to ensure cool and stable performance and each kit is fully XMP 2.0 compatible, allowing users to instantly set their memory to its specified speed and achieve the best possible performance and stability. CORSAIR Vengeance LED launches today with a wide variety of capacities and speeds to provide users with a wealth of upgrade and PC building options. Available in 16GB 2 x 8GB module, 32GB 4 x 8GB/2 x 16GB module and 64GB 4 x 16GB module capacities, and frequencies from 2,666MHz to an astonishing 4,333MHz, Vengeance LED is ready to power everything from high-end content creation and 3D rendering work stations to the most ambitious of gaming systems. Kits running at 2,600MHz and 2,666MHz run at 1.2V, while kits at frequencies of 3,000MHz and higher run at 1.35V. All Vengeance LED memory is backed by CORSAIR’s lifetime DRAM warranty.
