This is just a quick little review for those of you who may not like the feel of mechanical keyboards or are on a budget.
First of all this isn't a high end keyboard, I picked it up for only $40 from Newegg. I say this because this keyboard doesn't feel in anyway like a mechanical keyboard. It reminds me of the G15 I had several years ago, a quality rubber dome keyboard. This one does have much better lighting however.
Pros
Cheap
Quiet
Good typing experience - Of course this doesn't apply if you think mechanical switches are the best thing since sliced bread.
No SOFTWARE! Everything is done via the FN key and shortcuts.
Media keys
Lots of lighting options
Cons
Media keys aren't backlit
Backlight is very open so the light comes out around the keys also.
No individual key color options, 3 lighting zones
I am most definitely an outlier in this case, but I have tried three mechanical keyboards and I just don't care for the typing feel (blues, greens, romer-g). So if anyone out there feels the same way or you don't have a lot of cash to throw down on an rgb board this may be a good option for you.
I will be glad to answer any questions if anyone has any.
Pros
Cheap
Quiet
Media keys
Cons
