Corsair H70 Water Cooler Performance Testing @ [H]
Discussion in 'Overclocking & Cooling' started by FrgMstr, Sep 28, 2010.
  1. BigRigDriver
    BigRigDriver Gawd
    611
    Nov 25, 2005
    Forget this thing, get a Noctua or a good Zalman air.
  2. vic243
    vic243 n00b
    1
    Mar 19, 2011
    Not if you want to combine it with some good memory like the Corsair Vengeance. I learned the hard way cause I got a Noctua NH-D14 for a 2600K and combined with 16G of Corsair Vengeance...FAIL! :mad:
  3. Blackstone
    Blackstone 2[H]4U
    3,065
    Mar 8, 2007
    Does this cooler require a backplate on the mobo to install?
  4. FrgMstr
    FrgMstr Just Plain Mean Staff Member
    48,348
    May 18, 1997
    There are pin holder mechanisms that must be put into the back of the board....no plate though.
  5. Blackstone
    Blackstone 2[H]4U
    3,065
    Mar 8, 2007
    How would I install this into a Silverstone FT01? Where would the radiator go?
  6. tat098
    tat098 n00b
    2
    Mar 26, 2011
    "The Corsair Hydro Series H70 High Performance CPU Cooler is a top performing all-in-one liquid cooling system"
    what does "all-in-one" mean?
    does the h70 include cooling video card + cpu?
    are there cooling kits that are really "ALL IN ONE" that cools video card + cpu?
  7. Night_Hawk-19
    Night_Hawk-19 Gawd
    761
    Jun 20, 2004
    Fans Corsair gives are crap. Get better 120mm fans and decent air flow with fans.
  8. maverick786us
    maverick786us [H]ard|Gawd
    1,923
    Aug 24, 2006
    What degrades in this coolars that end up their life? Is H70 Idle for those who plan to keep their PCs for 5-6 yr?
  9. ARA662
    ARA662 [H]Lite
    72
    Oct 29, 2004
    Can you recommend one with high CFM Airflow that is also quite?
    With all the marketing it's really difficult to believe.
  10. yujie
    yujie [H]ard|Gawd
    1,105
    Apr 15, 2002
    How does this compare to the H60?
  11. garetjax27
    garetjax27 Limp Gawd
    178
    Feb 24, 2006
    I am currently using two Noiseblocker NB-Multiframe fans in a push/pull configuration with my H70 setup. They're 120mm case fans running at 1,800RPM and pushing 73CFM at 27dBA.
    The fans are whipser quiet, and my idle/load temps (as well as noise level) are very good compared to the stock fans that come with the H70. Overall, I am very pleased with my Noiseblocker fans and would highly recommend them.
    http://www.frozencpu.com/products/8...5mm_Ultra_Silent_Fan_-_1800_RPM_-_27_dBA.html
  12. dave343
    dave343 [H]ard|Gawd
    1,563
    Oct 17, 2000
    I just picked up the H70 and couldn't be happier with the performance/sound, although my first pump was defective. I was using the stock amd cooler on my 555 unlocked, temps were 45c idle, and 62c load. Now with the H70 I'm getting 27c idle, and 38c full load, and this is with the 555 unlocked to X4 @ 3.6 w/1.31V. Prime stable. Going to push for the 4.0 but time is my enemy.
  13. moomaster716
    moomaster716 [H]Lite
    67
    Apr 13, 2008
    To bad my case has no 120mm fan slots. This looks like a perfect middle ground to silence and overclocking.
  14. hoodisboi
    hoodisboi [H]Lite
    118
    Dec 14, 2006
    wooo getting this today! currently awaiting 6 more hours!
  15. neoamd
    neoamd n00b
    18
    Mar 29, 2009
    I'm using the H70 with 2 CM Excalibur fans and its doing a fantastic job keeping my CPU cool.
  16. Lamont
    Lamont 2[H]4U
    3,285
    Oct 26, 2004
    Using Gentle Typhoon AP-15's. Freakin' stock fans are loud as hell. It is a great cooler, and fits in tight areas where larger air coolers can not.
  17. hun77777
    hun77777 Limp Gawd
    154
    Apr 14, 2011
    i'm surprised this was cooler than D14
  18. Freiya
    Freiya Gawd
    550
    Apr 2, 2011
    What are some temps people are getting with oc'd sandybridges @ 100% load? I'm wondering if one of these would be a good step up from a 212 +
  19. hwtime
    hwtime n00b
    52
    Nov 20, 2010
    I might pick one of these up to try. Seems pretty solid
  20. neural0
    neural0 Limp Gawd
    360
    May 22, 2011
    Good review, I wonder how much hotter my motherboard would be running without the cpu cooler blowing down onto it
  21. upallhours
    upallhours Limp Gawd
    148
    Nov 3, 2010
    I have an OCed 2500k 4.4ghz 1.26v.
    Using real temp and Prime95 running for an hour I never saw temps over 65c. Idle temsp are around 31-33c. I am using an included resistor for the H70, plugged into the cpu fan header and in the recommended push pull as intake.
    Only complaint is it is still noisy with resistor, planning on replacing with gentle typhoons though.
  22. Nside
    Nside Limp Gawd
    259
    Jun 2, 2011
    For those concerned with drawing air in from the back of the case, just do like I did and make your side fan an exhaust... works great for me...
  23. bonnev659
    bonnev659 Gawd
    628
    Jun 21, 2011
    thanks for the info guys,
    this helped me when looking into a H70 when doing my first ever built
  24. ioric18
    ioric18 Limp Gawd
    176
    Jun 18, 2011
    I posted this same question on the Antec Kuhler thread:
    Anyone knows if I can switch the 120mm fan? I'm planning on a m-atx build but the case (thermaltake A30) I'm looking at has some non-regular fans -- two 60mm on rear.
  25. Instynx
    Instynx [H]Lite
    106
    Feb 18, 2008
    Got a question for you guys; Is it possible or advisable to change the tubing on the H70? I like the simplicity of the all-in-one design but I'd prefer to have clear tubing with red fluid.
  26. Enthusiast Extreme
    Enthusiast Extreme Limp Gawd
    334
    Jul 1, 2011
    I also have H70 in push pull, great little kit :D
  27. Curlack
    Curlack [H]Lite
    94
    Apr 1, 2011
    I don't believe im in a situation where watercooling is an option i'd think about, however I have been looking into the various kinds of watercooling there is.
    The H70 does appeal to me, however I am a man who lieks his asthetics, so the fact it's all in black piping really irritates me, and on top of that apparently the fan noise is something that really is an issue.
    I think, like what many people have said here, if they fixed or got rid of the fans in them, and then added maybe clear tubes or just something a little more "pretty", it'd be ideal. I only say this because when people spend say $300 on a Corsair 800D case or the like, i'm sure they want the insides of thier PC to look pretty too, haha.
  28. Redbeard
    Redbeard Official Corsair Rep.
    1,859
    Nov 3, 2005
    This is possible, people have done it, but be aware that the reason for the tubing we use is to prevent evaporation. Switching to clear tubing will void your warranty and you'll need to fill the unit as clear tubing has much higher evaporation ratings.
  29. TheWeazmeister
    TheWeazmeister <a href=http://www.blogcdn.com/www.parentdish.com/
    3,346
    Jul 16, 2010
    Tell me you didn't use "pretty" to describe a [H]ard "project." Visually pleasing, aesthetic, whatever...just don't bring that {s}oft word "pretty." :D
  30. Curlack
    Curlack [H]Lite
    94
    Apr 1, 2011
    Hahaha. My bad. Okay so it's visually pleasing to the aesthetic types like me (;
  31. Lamont
    Lamont 2[H]4U
    3,285
    Oct 26, 2004
  32. blueled
    blueled n00b
    22
    Aug 24, 2011
    I have a 2600K overclocked at 4,5 GHz, idle it's around 30°C, but at full load, after a long Prime95 session it reached 69°C, ambient temp around 25°C, should it be considered normal?, I'm not very happy with these temps...
    Note I switched fans to 2x Gentle Typhoon running at around 1400 rpm, but orientated inside - out, since my Lian Li keeps it really cold and I don't want dust coming inside.
  33. vengence
    vengence Level capped
    18,471
    Nov 7, 2007
    You're temps sounds about right to me. 25C+43.6= 68.6 and you're getting 69. Don't know what you're complaining about.
  34. blueled
    blueled n00b
    22
    Aug 24, 2011
    Easy. Don't know, maybe some benchmarks I read were just too optimistic... Truth is that after more intensive testing it newer went higher, and after stopping it made a great work taking temps down pretty fast, so I think it's ok.
  35. vengence
    18,471
    Nov 7, 2007
    Well I'm just saying the review you're replying to's data pretty much exactly matches what you've done. There's keeping a 44C delta on a 2600k OCed to 4.5 Ghz isn't exactly easy.
  36. Roscowgo
    Roscowgo Limp Gawd
    429
    Aug 12, 2009
    Is it possible to buy longer sections of the stock tubing? For those of us who don't have a 120mm spot and want to have it outside the case?
  37. merlin87
    merlin87 Gawd
    964
    Aug 18, 2001
    I am looking into different coolers for my setup in my sig. My office is pretty warm and usually 10-15* hotter than the rest of the house because of the sun during the day. Would I get better overall cooling with one of these than a regular air cooler?
    I also leave my comp on 24/7 and it hardly is off. Is there a risk of the liquid evaporating over the years?
  38. pendinglf
    pendinglf [H]Lite
    68
    Oct 8, 2011
    looks nice, I like it .
  39. TheWeazmeister
    3,346
    Jul 16, 2010
    Anyone know if this will fit in a Raven 02 case?
