DisrupTer911
- Oct 14, 2004
I'm looking to upgrade my HSF setup to a self contained W/C setup in the form of either the following
Corsair H50
or
Corsair H70.
I want max cooling for stock speeds and overclocked to 4-4.2ghz and maintain stability in temps.
My question is what the fan configuration should be.
I want to run in a push-pull configuration for sure.
I wanted to know tho, is it necessary to space the fan off the radiator some to allow for better airflow over the entire radiator instead of having a deadspot in the middle?
Should it be just a few millimeters or the space of an empty fan shroud?
Also, would it be beneficial to run the pulling fan at a higher speed then the pushing fan?
I plan to also cut out the fan grating on the case itself so there's no hindering of the airflow.
My next question is, which is the better cooler for a push-pull setup on an AMD x6 1090T CPU? the H50 or the H70.
Thanks in advance everyone!
Corsair H50
or
Corsair H70.
