I wonder how this would install in the NZXT Phantom case.
Even with a big heatsink, It looks like a tight fit:
http://nzxt.com/new/images/_upload/product_gallery/_MG_8934.jpg
& since the Phantom case only has one 120mm rear exhaust, IDK.
Are the top 2 fans 140mm? It will probably also have the 120mm holes as well. It looks kind like an upgraded version of the one I have, (the WC holes are below the fan holes finally!). Swap out the 140mm fan from the top with the 120mm fan from the back vent, and youll have more room to mount the radiator. Or just stuck it to the roof in place of one of the 140mm fans.
Anyone got any 120mm fans they would recommend with an h50 or h70? I don't like the stock fan so much.
I'll be sticking my GT AP15s on my H70. The included fans feel very cheap to me and just don't look or feel like "I can push air through a thick ass radiator." I don't know that they actually ARE cheap, and I don't know the static pressure specs on them, but they seem that way.
& the GTs are cheaper ($13-15).
I wasnt 'turning' this into a 'price' debate, I was simply stating how much they were is all.
I don't know why you turned it into a price debate lol, the Gelid's are PWM fans which generally cost more than 3 pin fans. Also, PFPCS may sleeve the GT's, but the 1850's are $18 and with shipping it comes out to ~$47, while the already sleeved Gelid total via Directron comes out to ~$43. I was just giving Langly options, because the GT's were too loud for me and thought it might be something Langly might care about. Furthermore, if noise isn't an issue the Gelid's still cool a tad better running at full speed...
Performance-PC sleeves them for free.
Thank youHey guys. The price of fans has jack shit to do with the H70. Just sayin'.
i7 930 @ 3.9ghz is running Fairly cool in a very very hot room. 75C with Linx. 60C while gaming. Still a good cooling system if you dont want to get a full blown WC setup. The tubing is a LOT easier to deal with on the h70 too.
My .2 cents
Just thought I'd pop in and report my H70 results now that I've had time to get a stable OC going.
H70 with two Scythe GT-AP15 in P/P.
i7 930 @ 4.2GHz
VCore 1.35v, everything else stock/auto.
RealTemp peak during LinX was 76/74/73/71c
Could try to push further I suppose but 4.2 is fine for me and any further will require more time spent tinkering with voltages.
