Spare-Flair
- Apr 4, 2003
I just bought and installed an H80 today after finding the H100 was a few mm shy of fitting into my case properly. My fingers are pretty raw now as I've been struggling to tighten the bolts on my H80. What perplexes me is that the ones I have have no screwdriver slots cutout on the bolts so I can use a tool to help me. It was very difficult getting the screws in the corners by the blue motherboard heatsinks to tighten. I'd imagine someone with larger hands not being able to do it at all.
All the images I find on reviews and other installs and the instructions show bolts that have screwdriver slots so I'm wondering if this is a new revision or if I'm not tightening my bolts enough as it feels like my temps are a bit higher than I would expect (I understand that ambient will be higher over air coolers). There's absolutely no way I can tighten these anymore with my bare hands and I'm worried that not enough pressure is being applied. The ones in the corners by the heatsinks were a real PITA.
