Hello everyone,
I just built a brand new Core i7 930 system in a Corsair 800D case using the Corsair H50 cooler with two Scythe S-FLEX SFF21F 120mm fans in a push pull config. The fans are rated at 28dBA @ 63.7 CFM - while spinning at 1600RPM. So pretty quiet overall while moving a significant amount of air.
As this seems to be true in a single fan config, but when both fans are installed in the push-pull config, there is a significant noisey whine coming from the fans. Is this normal? I currently have one fan plugged into the CPU_FAN header of my MSI Big Bang XPower board and the other onto a separate system fan header. Looking at the BIOS, the fans are spinning at slightly different speeds. Could this be causing turbulence and therefore the associated noise? Is there a way to keep the fans at the same exact speed using some kind of splitter?
