Corsair AX1200i and Radeon R9 295x2
GT98
I'm the in process of getting my parts for my new PC build and I was reading the Hardocp.com review of the R9 295x2 and its power requirements it needs. With that being said, which ports on the Corsair AX1200i should I plug the PCIe power connectors to? I did a quick look through the directions that came with the Corsair PS and didn't see a break down as to how the power was delivered to ports on it.
SpDFre@k
For the 295X2 you can use any of the PCIe connectors. You should only use the cables with single connectors for power. The single cable with two connectors on it will not hold up to the power draw of that card.
GT98
Yeah thats what I winded up doing...part of the issue is the AX1200i is a single rail and the info put on the review on [H] was for a two rail PS. Works fine...
Thug Esquire
Thanks for coming back and actually saying what you did. Just saved me some time, seriously.
